Sponsored by: Real Truck
Power window help
Old Aug 24, 2010 | 08:39 PM
aMw_fl's Avatar
aMw_fl
Power window help
Ok, I have a 99 F250 SD 4x4 Ext Cab. A couple of months ago the passenger side window quit working altogether. After reading different posts on here, I figured it was the switch. So I replaced it and same result. So I ordered another motor, still nothing. I am waiting on a regulator tomorrow, but I don't think that will fix it either. When I had the motor out, but still hooked up it would only go one way. It was the same with my "old" window motor as well as the new one. I have three stitches in my thumb from unbolting the regulator, as you can tell it's about to really **** me off!
Any suggestions would be greatly appreciated.
Old Aug 24, 2010 | 09:02 PM
mrford60's Avatar
mrford60
i don't know if you have tried this or not, but the passenger side is controled by 2 switches if one is bad it might not let the other one work. other than that it must be in the wiring.
