Speedo change out
Old Feb 2, 2016 | 04:57 AM
Ryder12's Avatar
Ryder12
Speedo change out
Guys I am still working thru issues to fix for registration, one thing I am struggle to do is buy a speedo cable (correct one)as I do not know what I need. I removed current speedo which is about 2.4 Mtrs long from 68/69 f350 with a 351 Cleveland motor. Any help is appreciated to confirm what one I need.
I have confirm speedo mechanism still works it's the cable that is damaged.
Cheers
Old Feb 2, 2016 | 07:53 AM
Freightrain's Avatar
Freightrain
The big difference is between AUTOMATIC and Stick shift. The way it attaches to the transmission. Automatic screws on, the stick shift slides in and gets held by a clamp with 1/4" bolt.
Old Feb 2, 2016 | 09:10 AM
351Cleveland C4's Avatar
351Cleveland C4
All my automatics are slide in with the clamp holding them....
An F350 with a Cleveland engine? Odd combination.... Are you sure it's a Cleveland? Not a 400 or 351 Modified? Edit: I see you're in OZ, that explains it. They used them in everything down under!
Old Feb 2, 2016 | 09:14 AM
GLR's Avatar
GLR
If the housing is not damaged, you can buy just the cable, cut to length and crimp on one end. Not sure whats available in Australia.
Old Feb 2, 2016 | 01:49 PM
Freightrain
Hmm, my '69 with C6 was screw on style.
4tl8ford
Mar 7, 2014 09:48 PM
ol orange
Aug 14, 2010 12:48 PM
78Ranger_GARedNeck
15
Apr 3, 2008 04:09 PM
64fordf100292
Sep 17, 2007 10:40 AM
Mithrandir
Jun 1, 2004 07:27 PM
