speedo issues please help
truck was originally 3 speed on tree but now has a np435? anyways could it be i need a special speedo cable for the np? its 2wd btw.
any advise would be great
I would pull the cable out of the transmission and spin it by hand and watch the speedometer to see if it moves. If it does, then you would want to look at the speedo. drive gear in the transmission.
If it doesn't move, pull the speedo. and spin the speedo. itself by hand to see if it moves. If it does look long and hard at the cable assy to see if its bad.
