T-18 Problem
Old Feb 1, 2016 | 12:40 PM
Frusrated's Avatar
Frusrated
T-18 Problem
I MADE SOME REDNECK ADJUSTMENT TO MY SHIFT CANE, OF COURSE BEING A 88 F-150 THE PIN WORE AND SLOPPED. SO I REMOVED CONTROL AND NOW AFTER REINSTALLING I CANT EVEN FORCE INTO REVERSE. I HAVE ALL GEARS, IT JUST WONT GO IN REVERSE. DONT SEE IT ! HELP IF CAN. THANK YOU...
Old Feb 1, 2016 | 01:25 PM
AbandonedBronco's Avatar
AbandonedBronco
Hello Frustrated, welcome to the forums.
For starters, please do not type in all caps. It's not only difficult to read, but is considered yelling, which can be taken as rude.
Also, this has nothing to do with the engine, so I'm moving it to the appropriate forum.
Old Feb 1, 2016 | 05:40 PM
Frusrated's Avatar
Frusrated
I apologize for the all caps and I'm not the best at this sort of thing, in fact my first try at a forum. I am however frustrated and would appreciate any help I can get. All I did was take off the shift control, to drill and put in drill bit pin. I have it back in and it will not drop into reverse. I have 1st, 2nd, 3rd & 4th. Any advice helps. Thank you in advance.
Old Feb 3, 2016 | 09:18 AM
Alexz265's Avatar
Alexz265
The reverse idler gear can slide (probably backwards in this case) and though you were able to line up the two other forks, u may have missed the slot on the reverse idler. The third fork (which is a single arm) controls the sliding of the reverse gear). You should be able to fix it by removing the top cover and taking a long screwdriver and sliding the idler gear to the correct position. It is located on the driver side aft section of the case interior. In the future for cane removal, its best to put the trans in neutral and only remove the cane.
Edit: I see you removed it to modify the pin hole. Disregard the last sentence
Ford till I rest
Jul 8, 2016 10:53 AM
mech1
Jan 20, 2011 04:56 AM
Knightrocker
2004 - 2008 F150
Jan 25, 2010 10:30 PM
asok
Oct 14, 2009 02:53 PM
cjbronco
1978 - 1996 Big Bronco
Jan 24, 2005 06:42 PM
