uvc harness
Old Nov 26, 2006 | 07:27 AM
ponch37300's Avatar
ponch37300
uvc harness
I have read about the uvc harness problems. I did some searching cause i was going to do my gps and was told that my 03 had the updated uvc harness with the clips to prevent it from coming unplugged. When i got the valve covers off both sides had the uvc clip to hold the harnesses together on the outside of the uvc harness but the inside was missing that little clip that holds the harness to the valve cover gasket. Are there supposed to be clips on the harness inside of the valve cover as well as on the harness outside of the valve cover? If there is supposed to be clips on the harness inside the valve cover where is the best place to get two of these clips to put in? Thanks
Old Nov 26, 2006 | 07:33 AM
Uzumati's Avatar
Uzumati
See if this helps ponch
http://www.forddoctorsdts.com/articl...icle-05-10.php
Old Nov 26, 2006 | 05:46 PM
ponch37300's Avatar
ponch37300
I've read that article and the clips i have on the outside of the harness don't look like the ones in the pictures. Are there supposed to be clips on the inside also or just on the outside. The clips i am talking about are after the harness is plugged into the connector on the valve cover gasket there is a clip that snaps in and "locks" the harness to the connector. I have these clips on the outside of the valve cover but not on the inside side of the valve cover gasket connector. Thanks
Old Nov 26, 2006 | 06:45 PM
Uzumati's Avatar
Uzumati
Clips on the inside are for the old style connector before ford "fixed" the problem
