The only ones I've been able to get to work are Fuel Level Percent Remaining, Transmission Fluid Temperature and Ambient Air Temperature.
The transmission reports in to the OBD system, and I understand there's a few more things the ScanGauge could report, such as Torque Convertor slippage, Output Shaft Speed, that sort of thing, but I don't know the codes for those.
here is the other code I have. Barometric Pressure but I don't know what good it would be to monitor. I think the computer uses it for fuel mix.
07DF0133 TXD
044185330000 RXF
2808 RXD
006400450000 MTH
