1998 Engine Code 0455
Old Sep 29, 2003 | 01:14 PM
jayhawkfan's Avatar
jayhawkfan
Question 1998 Engine Code 0455
My check engine light came on and the code was 0455 - Evap. system leak. I can smell gas fumes on the driver's side from the door back. Anyone know what the most likely culprit may be? I checked hoses from the filler tube and they appear to be OK. Can't say for sure if the gas fume odor is coincident, but the bed was removed and replaced after an accident in July.
TIA
Paul
Old Sep 29, 2003 | 01:22 PM
Rockledge's Avatar
Rockledge
Paul,
If you look up your code (P0455) here you will get a better idea of the problem and its possible causes:
OBD-II Diagnostic Trouble Codes
