68 F250 Cooling Problem
FYI
I have owned this 67 F250 for 40 years and that was an issue no matter what I did
UNTIL
I found out that these FE motors REALLY don't like the retarded timing at idle. I also found out how to WAKE the engine up, give it a ton more power at low RPM's and STOP the cooling problem.
Are you listening?
I was setting the old boy about 4 degrees initial timing. I had a Crane Adjustable vacuum advance unit to allow me to set the advance just so it wouldn't knock..
What I found out was a goldmine to me.
Here you go...I bet it'll work for you too but if you aren't a gearhead you will need help.
These motors will give you much better low end and more manifold vacuum at idle when they are set to about 12-14 degrees initial timing. The problem is that the Motorcraft and Autolite distributors are sent from the factory at 30 degrees MECHANICAL timing. Remember back then we used REAL Gas (106 octane leaded fuel) so the engines ran much cooler in the combustion chamber. Less heat. Less Ping or Knock.
Ok...take 30 degrees mechanical plus the 6 we put in by twisting the distributor while using a timing light and that gives us 30+6=36. (at 36 mine would knock under WOT)
If we tried 30+14=44, the engine would knock upon the hit. 44 degrees would quickly KILL the motor.
My 465 CID Cobra is set RIGHT NOW at 14 degrees initial advance.
But 20 + 14 = 34...BINGO.
Engine has MUCH more response and runs cooler and enjoys higher idle vacuum. NICE
So...Ford engineers were smart.
We can change the placement of the weights inside the distributor to allow 20 degrees mechanical advance instead of the stock 30 degrees.
We then add the needed advance with the timing light.
Got it?
Look up the modification with an internet search.
Enjoy.
P.S. You'll awaken the beast.
Bill
UNTIL
Are you listening?
Got it?
Enjoy.
Bill
pmoraldo
18
06-09-2011 10:43 PM
