Australia Chapter Join Chapter , Leader: OPEN
Code Reader diagnostic tools?
Old Jan 27, 2016 | 05:42 PM
Daz-51's Avatar
Daz-51
Hi, New to site, Base in Perth Western Australia, 2006 7.3L crew cab 4X4
What tools, code readers, diagnostic programmes are people using to monitor and diagnose engine faults and sensor values?
Thanks
Old Jan 27, 2016 | 06:35 PM
Aussie BrianB's Avatar
Aussie BrianB
Daz,
g'day, and welcome.
I am using the AutoEnginuity program.
I was quite happy with it when I first bought it at version
10 point something but the latest version 12 update is a
big disapointment.
Reverting to an older version is problematic.
There are other programs that are bettter suited.
I am sure some wiser heads on the forum will be better able
to advise you.
Old Jan 27, 2016 | 09:07 PM
Daz-51's Avatar
Daz-51
Hi, Interesting that AE is disappointing, I was leaning towards AE as other blogs this is the only one to have, Can somebody confirm if it's correct that the Australian, brazil made trucks use the scanners, diagnostic software as the USA trucks?
Old Jan 28, 2016 | 11:46 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Hey mate - I don't have a 7.3l, so can't verify if this works as well with your truck as it does with mine, but I personally use Forscan. Its free (just need a cable or bluetooth OBD2 dongle to connect it to a laptop).
Given the price, its probably worth checking out.
What's new
If you get a bluetooth OBD2 dongle you can also download an app to your phone which will allow you to check most PIDs, but they don't do diesel specific items.
Old Jan 29, 2016 | 03:43 AM
Aussie BrianB
Adrian.
Does Forscan talk directly to USB or do you need to use a
USB to COM port adapter?
Old Jan 29, 2016 | 06:08 AM
Daz-51's Avatar
Daz-51
Thanks BigF350, will look into them.
Old Feb 1, 2016 | 12:28 AM
Blue7.3's Avatar
Blue7.3
AE will work the same with US built trucks and ours , the new version of AE is Giotto 13.1 is an easy set up to use and well worth the money.
You can also use the SC 1705 as a code reader if you have one.
Old Feb 1, 2016 | 04:50 AM
Aussie BrianB
Before you fork out the cash for AE read this thread.
https://www.ford-trucks.com/forums/1...otto-fail.html
Old Feb 4, 2016 | 02:56 PM
BigF350's Avatar
BigF350
FTE Emeritus
Originally Posted by Aussie BrianB
Adrian.
You just need an OBDII adapter for your laptop.
Either a USB or Bluetooth one (I have the latter so I can also use the adapter with my phone)
Old Feb 4, 2016 | 03:25 PM
Blue7.3's Avatar
Blue7.3
This one is available on fleabay for around $20 .
Old Feb 5, 2016 | 06:26 AM
Aussie BrianB
Thanks Blue
ryanf250
Dec 27, 2012 09:00 AM
Mark Alligood
May 22, 2012 09:07 PM
BigSix1
May 16, 2010 10:13 PM
gearloose1
General Diesel Discussion
Jan 22, 2010 08:11 PM
Paxcam
Feb 4, 2003 11:41 PM
