Sponsored by: Real Truck
code reader
Old Dec 21, 2012 | 03:55 PM
ryanf250's Avatar
ryanf250
code reader
I have a service engine light on my 05 f250 5.4 gas, what is a good code reader to get,any software avail. for a laptop, any cable to computer interfaces, give my your ideas? thanks
Old Dec 21, 2012 | 05:12 PM
maverick22's Avatar
maverick22
The sky's the limit - what do you want to spend? Your options range from taking it down to your local Autozone or similar and having them scan it for free, all the way to buying a professional grade scanner. If you want to use your laptop, there's a program called Autoenginuity that's very well respected and w/ the Ford bundle will do nearly everything the dealer's will.
Pretty much any cheapo scanner will read engine codes but if it's anything ford specific you'll need a higher grade tool.
Old Dec 21, 2012 | 06:51 PM
SC_Hoaty's Avatar
SC_Hoaty
+1 on what Maverick said. I know some of the diesel guys swear by AE - but they have more need to get into what the computer thinks it is doing to their motor. If all you need it is the code read, go to AutoZone - they do it for free. After you get the code, research ALL the things that could cause it. Sometimes it is the sensor, sometimes the sensor is reporting a problem elsewhere in the engine. And some are just a random nuisance. Reset and see if it repeats.
Old Dec 21, 2012 | 08:41 PM
ryanf250's Avatar
ryanf250
cool, how much would the labtop with the ford scanning capabilities set me back, how do you reset it, I'm a little uneasy with autozone, worried their unskilled possibly unknowlegeable employee could mess up my ecm accedently
Old Dec 22, 2012 | 12:39 AM
mrcllusb's Avatar
mrcllusb
The AE program with hardware will run you 400.00
Old Dec 22, 2012 | 02:12 AM
Yahiko's Avatar
Yahiko
This is also a decent option for reading and the monitoring
capabilities it has and you don't to have a laptop in the truck
to get stolen. AND you can all the Xguages to it
ScanGaugeII : Linear Logic - Home of the ScanGauge
$160 at Autozone if you want to pick up locally.
Sean
Old Dec 22, 2012 | 07:44 AM
SC_Hoaty's Avatar
SC_Hoaty
+1
Look here at the Ford Scan Tool Bundle - scroll down to see it.
Order Online
Old Dec 22, 2012 | 08:57 AM
ryanf250's Avatar
ryanf250
thanks for all the options, now I need to get on it....thanks
Old Dec 23, 2012 | 12:49 AM
Edogsf350's Avatar
Edogsf350
Just purchased my AE from riff raff for less check them out. bought it on Sunday got it on Wednesday.
Old Dec 26, 2012 | 11:07 AM
ryanf250's Avatar
ryanf250
ok, need a few more answers...I havent decided on which code reader to get yet so I went to autozone, had the chick read the codes, and she says it said the thermostat was faulty, now my temp gauge stays in the normal, but thats not to say its sticking open just a little to not allow the engine to reach full operating temp...hence throwing a code, so I bought a new thermostat, first question is, is the antifreeze used by ford oem different than the green prestone?, and should i expect to have to bleed the air out of the system as I refill it?
Old Dec 26, 2012 | 03:20 PM
ryanf250's Avatar
ryanf250
ok, called ford, they say use ford gold antifreeze, so i replaced the t-stat, how do i reset the service engine light, pull the ecm fuse? remove battery?
Old Dec 26, 2012 | 03:26 PM
SC_Hoaty's Avatar
SC_Hoaty
Originally Posted by ryanf250
... first question is, is the antifreeze used by ford oem different than the green prestone?, and should i expect to have to bleed the air out of the system as I refill it?
Yes, it is different.
Read your owner's manual - it has specific instructions about which coolant to use and which one to avoid. Start on page 257.
Old Dec 26, 2012 | 03:28 PM
SC_Hoaty's Avatar
SC_Hoaty
Get the guy at the auto parts store to do it with their code reader.
Old Dec 26, 2012 | 03:29 PM
SC_Hoaty's Avatar
SC_Hoaty
Or the chick!
Old Dec 26, 2012 | 08:09 PM
tazaxx's Avatar
tazaxx
For about $20 you can get a Bluetooth dongle (plugs into your OBDII port) off Ebay, then download an app on your smartphone. There are apps for either iPhone or Android. The apps are pretty cheap depending what you get.
