Backup Lights and vacuum pump not working
Old Jan 25, 2016 | 10:36 PM
hkimmer's Avatar
hkimmer
My 16 year old F250 4X4 diesel has developed a problem with no backup lights working, and the vacuum pump is not getting power. The fuse (#28) checks out OK, and I'm told to check for a broken wire on or near the backup switch. I don't know where to locate the backup switch. I have the huge Ford Service manuals, but they are written with the perspective that you should already know where the switches are. Can someone tell where to find the switch? Any other trouble shooting suggestions will be most welcome.
Old Jan 26, 2016 | 08:49 AM
DND58's Avatar
DND58
Just guessing, but try the passenger side of the transmission.
Old Jan 26, 2016 | 05:36 PM
Dirtscooter250's Avatar
Dirtscooter250
For vac pump you will probably have to trace continuity of power harness.
For the reverse wires, the range sensor on the trans (assuming auto) has a blk and pink tracer wire off it for chassis reverse. Check that for power. If that checks out, there is a black with green tracer wire that runs from the fuse panel to the reverse for trailer plug and drivers kick panel. Check that one as well because if that gets power then the range sensor is sending a signal
Old Jan 29, 2016 | 11:43 AM
hkimmer's Avatar
hkimmer
backup lights / vacuum pump makfunctio
Thanks-a-ton Guys, this is an automatic tranny. I thought the switch would be obvious, but it may look more like a sensor than a switch. Is it possible that the what I'm looking for could be combined with the neutral safety switch?
Old Jan 29, 2016 | 12:01 PM
Dirtscooter250
Well, neutral safety switch is jumpered so the neutral sens is at the range sensor.
BlueOx460
Jun 26, 2017 08:51 PM
WINGNUT-
13
Nov 26, 2010 08:07 AM
Dskeet6
Sep 14, 2010 10:29 PM
smithbks
May 17, 2009 07:22 PM
hyenaroo
Jul 26, 2001 08:05 PM
