Sponsored by: Real Truck
Rough idle
Old Jan 25, 2016 | 11:40 AM
CBM91011's Avatar
CBM91011
Exclamation Rough idle
I have an exhaust leak between the manifold and turbo ( in the flex part of the pipe) on my 2008 6.4 f250 would this create rough idle when at operating temp??
Thanks in advance
Old Jan 25, 2016 | 01:28 PM
speakerfritz's Avatar
speakerfritz
so the turbo is two impellers (fans) on a single shaft. exhaust gases spin one of the impellers and that rotational energy is transfered to the other impleller which spins and increases the aire flow into the engine. a computer is programmed to mix fuel based on temp, air presure, etc. So having a leak between the exhuast manifold and the turbo will reduce the exhuast pressure and interfere with the correct amount of intake air and proper fuel/air ration mix as controlled by the computer. The 6.4 has 2 turbo's and the interrelationships are a little more complicated but the basic theory is the same.
Old Jan 25, 2016 | 08:08 PM
CBM91011's Avatar
CBM91011
Thanks for the info. I did fail to mention that it stalls on occasion when in park or in drive but only at idle speed not sure what is going on and if this leak is part of the problem but it's frustrating as hell.
skinny29286
Nov 19, 2013 06:46 PM
austinpowerz101
Oct 5, 2011 05:05 PM
HS400
Mar 16, 2009 09:29 PM
bigdieseldav
20
Apr 23, 2005 11:15 PM
powertemp
Electrical Systems/Wiring
Jan 13, 2005 09:09 PM
