Sponsored by: Real Truck
Transfer case problems and codes!!
Old Jan 21, 2016 | 10:57 PM
paradisemedic's Avatar
paradisemedic
Hello All! Great start to a new year right? I recently discovered when I engage my 4wd system the light on the dash comes on and stays on, but while driving it is almost like the truck is jumping out of gear. I hooked up AE and pulled the only code related to the transfer case and it was P1832. After a few rounds of googling I haven't really found any solutions. Do I have a wiring issue or solenoid issue or both!? Thanks in advance for the help! Oh by the way, not sure if it matters but the truck is an 02 F250, 7.3L Diesel.
Old Jan 22, 2016 | 07:15 AM
Diamnd1's Avatar
Diamnd1
Check your relays. Maybe one is going bad and shorting the circuit. If not the relay, then check the 4x4 module. And as always, check wiring as you go.
Old Jan 25, 2016 | 10:08 PM
paradisemedic
Ran the wiring and checked the relays, even put the truck up on stands and engaged the 4wd. All wheels turned in both directions...... as far as right now the truck is working. Thanks for the help!!
preppypyro
31
Mar 5, 2025 03:54 PM
Rusty Axlerod
Feb 16, 2014 07:59 PM
Benny2002
Aug 14, 2007 12:03 AM
Caper10
Feb 8, 2005 05:26 AM
