engine cool down vs. wet stacking?
Old Feb 4, 2004 | 06:33 PM
bigdieseldav's Avatar
bigdieseldav
I'm a bit confused, I've been told that it is bad to let my truck idle for more than 5-10 minutes due to running the risk of wet stacking and the introduction of fuel into the crank case.....
Now having said that i've been told its equally important to idle my engine down after running her hard or after a prolonged drive, and i've seen idle down timers talking about 20 minute idle down. Whats the correct answer???
Old Feb 4, 2004 | 07:19 PM
petes4x4's Avatar
petes4x4
the owners manual says to idle for 5 min. I put a pre-luber on my truck that also runs for 6 min pumping oil throught out the system to keep oil from cooking in the turbo.
Old Feb 4, 2004 | 07:21 PM
petes4x4's Avatar
petes4x4
sorry, it runs on shut down for 6 min
Old Feb 5, 2004 | 01:07 AM
WeWeld's Avatar
WeWeld
I have a Isspro turbo temp monitor that shuts the truck down when exhaust temps cool to 325 degrees.
GENE
Old Feb 5, 2004 | 06:17 AM
13hondacr250's Avatar
13hondacr250
I just watch my EGT and when it hits 300 I turn it off.
Old Feb 26, 2004 | 10:24 AM
broncoman85's Avatar
broncoman85
Going to pick my 02 psd (first diesel I've owned) up this afternoon....I'm bad about going into a parts house or other places and doing some bench racing and forgetting the truck's running....is wet-stacking a viable issue?
Later Whit
Old Feb 26, 2004 | 12:41 PM
Nickiboy's Avatar
Nickiboy
What the crap is "wet stacking" ???
Old Feb 26, 2004 | 12:46 PM
BluesManF250's Avatar
BluesManF250
WEWELD,
Do you have the turbo monitor wired to your pyro or some other way? If hooked to your pyro, how did you do it? Thinking of getting on of those myself.
Old Feb 26, 2004 | 05:27 PM
TJC1989's Avatar
TJC1989
I guess that all depends on your driving immediately prior to wanting to shut it dow. If you have been driving a long distance, such as on an interstate, and pull right off to a service station, or restuarant, you might benefit from a one or 2 minute "idle down" before shutting down, but if you are like me, either stopping when I get to work, or home, I have already been driving in a very reduced throttle condition because of the neighborhood, and traffic conditions, so the EGT's are already down. Still, when I get to work, or home, I generally let it idle another 15 to 30 seconds to be safe before shutting down.
Old Feb 26, 2004 | 06:51 PM
78fordman's Avatar
78fordman
wetsacking is when the engine cools down, due to a diesel not making enough heat when idling, and then garbage builds up on the exhaust valve, and then does not seat as quickly, and then the piston will hit the valve, and the pushes the pushrod, then the lifters expand to compensate, and then the piston hits it again, and the pushrods do not bund anymore and something major goes kaboom. Usually if you use powerservice or something simular greatly reduces the risk, because it keeps everything clean on the inside. Also that is why on newer diesels the pcm will raise the idle to about 1000 rpm to either warm the motor up or the keep it warm. I usually let my truck sit for about a minute idling after a long trip.
Old Feb 26, 2004 | 07:00 PM
Nickiboy's Avatar
Nickiboy
Thanks for the explanation Fordman........ Better not let my truck sit idling after startup.
Old Feb 26, 2004 | 07:47 PM
bkrfrmhell's Avatar
bkrfrmhell
You don't have to worry about wetstacking......idle your truck for hours and you won't have any real problems....I work in the arctic circle on large mining equipment and have only seen wetstacking once.... on a cat 3516.....fast idle program malfunctioned...truck idled at 700rpm for approx 40 hours straight at -50 degrees before there was enough build up on a valve stem to cause it to stick and smack the piston... people that worry about this in their pickup have way too much time on there hands...better to idle too long than not enough
Old Feb 26, 2004 | 07:54 PM
afinepoint's Avatar
afinepoint
The main culprit in wet stacking is not getting the engine hot enough to burn efficiently enough to remove the valve (stem) deposits.
When (idling) cold the fuel does not burn completely. The unburned products deposit on the engine components - mainly the exhaust valves. If these deposits are not removed the result can be a sticking or stuck valve. Because of the tight clearances between the piston and valve due to the high compression ratio of a diesel engine a stuck or sluggish valve can make contact with the piston. The results? A weekend doing a rebuild or $$$$ to your favorite mechanic.
The cure? Drive the truck before shutting down the engine. This will get the internals hot enough to burn the deposits off the valves.
Newer engines designs try to help out by boosting the idle to warm the engine faster.
No engine should or needs to idle excessively. Driving will always warm the engine faster and is the desired method.
Also, never race the engine prior to shutdown. You will spin up the turbine and then starve it of oil when the engine stops.
Reg
Old Feb 27, 2004 | 07:19 AM
powerstroker250's Avatar
powerstroker250
From Dieselmann's site http://www.intellidog.com/dieselmann/b_smoke9.htm
Old Feb 27, 2004 | 11:51 AM
kmill35's Avatar
kmill35
If I remember correctly, in 2000-2001 ford incorporated an extended idle program that if the oil temps fall below a certain point and/or ambiant temp is low it raises the idle and turns on an intake heater located after the intercooler and before the heads. It goes back to base idle when the brake or clutch is depressed. My 2001 work truck did that.
