Code P06EA
Old Jan 23, 2016 | 03:28 PM
4bigred's Avatar
4bigred
Code P06EA
Got a P06EA today. Heard from two different service advisors from the same dealership at home. The first said it would okay to drive home towing our 5th wheel. Other left a message advising not drive home. The distance is 600 miles from the Rio Grande valley to Ft. Worth. The truck has 29K miles. Finally, are there any recommendations for Ford service in the Mission/McAllen, TX area?
Old Jan 23, 2016 | 04:15 PM
F stock owner's Avatar
F stock owner
I can't advise you to drive or not to drive. If somebody else can, here's the code: P06EA - NOx Sensor Processor Performance (Bank 1 Sensor1)
Good luck.
Old Jan 25, 2016 | 09:22 AM
FordService's Avatar
FordService
Official Ford Rep
Hi 4bigred,
Since you're concerned, you may want to contact Ford Roadside Assistance to have your truck towed to the nearest dealership. They can be reached at 1-800-241-3673. Additionally, you can find dealers in the area where you are presently by entering the ZIP code here: Ford Dealers | Locate a Ford Dealer Near You | Ford.com
Crystal
Old Jan 25, 2016 | 09:32 AM
donovan's Avatar
donovan
NOx Sensor
If the dealer has the part in stock I would have them swap it out. If it just sensor it should be a quick fix.
I could be wrong the but the nox sensor tell the truck how much DEF to spay into the exhaust.
Old Jan 25, 2016 | 10:12 AM
egwilly's Avatar
egwilly
From the Diesel OBD System Book:
The NOx sensor is primarily used to sense NOx concentrations in diesel exhaust gas. The sensor is mounted in a vehicle’s exhaust pipe, perpendicular to exhaust gas flow between the SCR and resonator. The sensor is typically mounted, in an aftertreatment-equipped diesel exhaust system, upstream of the SCR and DPF on a Chassis Certified Vehicle and upstream of the SCR only on a Dynamometer Certified Vehicle. The sensor interfaces to a NOx controller module that controls the sensor element’s sense circuit and heater.
Should you continue to drive it? I can't answer for you, but I would not take the chance having the SCR system go into limp mode and shut down somewhere miles from a tow or dealer. The sensor could detect high NOX and do things you won't like!
Like noted before, it's most likely a warranty issue that Ford will honor.
Best wishes for a prompt repair! It's probably a fast fix.
Old Feb 4, 2016 | 12:00 PM
4bigred's Avatar
4bigred
Thanks for all of you for the replies. I was able to get it into Spike's Ford in Mission, TX. Got it back before mid-afternoon. All covered under warranty.
Old Feb 4, 2016 | 01:09 PM
FordService
Official Ford Rep
Great news, 4bigred! Thanks for coming back and sharing your outcome with us.
Crystal
NeilTDeal
24
Jun 20, 2014 02:03 PM
ERIC FORD
1997 - 2003 F150
Jul 7, 2012 05:07 PM
j250hd
May 18, 2012 10:58 PM
HVJ
Dec 27, 2004 10:35 AM
