That is the one I purchased and that price is good. It comes with a booklet with instructions and codes. Once you read a code it is a process to determine what is exactly the problem. You will need a repair manual as well.
Good luck, David C
don't waste your money. the hanes manual will give you the code #'s and tells you how to use a multimeter. your can get a manual and a multimeter for less money and the multimeter is alot more useful
