Driveshaft
Old Jan 22, 2016 | 12:48 PM
Mrich69420's Avatar
Mrich69420
Driveshaft
Driveshaft on my 91 150 snapped so gonna pull one from boneyard to swap it out wondering if anyone knows if a driveshaft from a 4x4 will fit 2 wheel drive
Old Jan 22, 2016 | 12:54 PM
glockholiday's Avatar
glockholiday
No, the transfer case on a 4x4 adds about a foot to the back of the transmission so the 4x4 shaft is that much shorter.
Old Jan 22, 2016 | 01:19 PM
Mrich69420's Avatar
Mrich69420
Any idea which ones would work I have 91 xlt larait with 8ft bed 5.0 automatic
Old Jan 22, 2016 | 01:47 PM
rla2005's Avatar
rla2005
There are two different four speed overdrive transmission available on this vintage truck, AOD and E4OD. One is a mechanical OD trans. and the other is electronic OD. They are different lengths therefore the drive shafts are going to be different lengths and perhaps the yoke as well. I suspect you have the AOD since that is the more common behind a 5L truck.
I would suspect a driveshaft on a 1987 to ~1993 F150 with an AOD and same bed length/cab should work. 1994 Ford started using the 4R70W behind the 5L trucks. As well as the same sprinkling of E4ODs.
Old Jan 22, 2016 | 02:08 PM
Mrich69420's Avatar
Mrich69420
What's my easiest way to tell which trans it is
Old Jan 22, 2016 | 02:46 PM
rla2005's Avatar
rla2005
Driver side Door jamb sticker: Trans Code T is an AOD. Trans Code E is an E4OD.
Item 3 below:
You can also count the number of bolts on the transmission pan. 14 bolts = AOD. 20 bolts = E4OD
Old Jan 22, 2016 | 02:49 PM
Mrich69420's Avatar
Mrich69420
Sweet thanks for the help
Old Jan 22, 2016 | 04:02 PM
animator's Avatar
animator
The easiest way to make sure you get the correct drive shaft is to take a tape measure with you to the junk yard.
You can determine your transmission by looking at the shape of the transmission itself, or by the shape of the pan. Do a search, it's pretty well covered...
Old Jan 22, 2016 | 04:20 PM
rla2005's Avatar
rla2005
Like this?
minnesotafisherman
Jun 26, 2012 09:24 PM
90f150302
Mar 3, 2010 09:18 PM
bobbykey
Feb 28, 2010 05:41 AM
danlee
Mar 26, 2009 06:39 PM
factoryphil
Jun 5, 2006 11:44 AM
