4x4 conversion question
Old Jun 25, 2012 | 06:43 PM
minnesotafisherman's Avatar
minnesotafisherman
Hey guys, finally going to make a move on a 4x4 conversion on my truck. I have researched plenty on this and have a good engine with only 60,000 on it in the truck and selling mine to buy a 4x4 is NOT an option.
Anyways I found a 1990 F150 4x4 302 V8 5.0 on Craigslist. It's an extended cab long box. The guy said it's a manual shift transfer case, automatic transmission, manual locking hubs. He only wants $500 for it, engine has issues, drivetrain is good.
My truck is a Standard cab F150, 302 V8 5.0, Auto transmission, 2wd obviously.
I assume a 1990 F150 with an automatic transmission would be an AOD tranny, right? Don't think the E40D's were around then. The only problem I could see with this is the rear driveshaft length, I would need it shortened, right?
I would imagine the front driveshaft would be the correct length?
Thanks
Old Jun 25, 2012 | 07:39 PM
UNTAMND's Avatar
UNTAMND
It's iffy on which trans. My 90 with 351 is an e4od. I have an 89 with 351 that's an aod. Both are 4x4. Your 2wd truck is an aod right.
Maybe the 90 with 302 is an aod also and it would be a sweet swap. Front driveshaft will bolt in. Rear will need to be custom fit unless you buy one.
Old Jun 25, 2012 | 07:47 PM
minnesotafisherman
Thanks for the reply...
Yep my '92 is an AOD, NOT an E4OD.
The truck is an hour from here, so I can't look at it. Would hate to make a second trip to go pick the thing up. Is an extended cab 4x4 F150's transmission any different in length than a Standard Cab 4x4 F150 transmission? Say they were both AOD's....
I know 2wd and 4wd trannys are different lengths.
If they are the same then I could just buy a rear driveshaft off a F150 from the Junkyard, instead of paying to have the driveshaft modified, which I would assume would cost more.
Old Jun 25, 2012 | 08:00 PM
UNTAMND's Avatar
UNTAMND
Yup. The front driveshaft will bolt right in.
And also yes. Find a 4x4 truck with body config that you have with aod and the rear driveshaft will work.
All the 4x4 aod trans are the same length. No worries about xcab and reg cab trans. They are the same.
Old Jun 25, 2012 | 08:08 PM
SCRebel's Avatar
SCRebel
It would take some work. But you can buy a 4x4 AOD output shaft, and tear down your current AOD and put the 4x4 output shaft in. www.wittrans.com sells AOD 4x4 output shafts for $50.
Old Jun 25, 2012 | 08:12 PM
minnesotafisherman
Alright thanks a lot for the help, it's much appreciated.
A relative might have a 25 foot trailer that I can use to haul this thing.
Old Jun 25, 2012 | 08:22 PM
minnesotafisherman
Sweet! Just found out from the guy that the tranny pan has 14 bolts, meaning it's an AOD.
Looks like this truck is perfect to convert mine to 4x4. Tear out the driveline, and sell the rest. Maybe I'll break even.
Hey Rebel, Just saw your post. I would probably do that if I knew how to tear down a tranny, lol.
Old Jun 26, 2012 | 07:32 AM
SCRebel's Avatar
SCRebel
Its all good. Thats what I did, cuz I have a great AOD tans I just rebuilt. Also just be careful you're no looking at a AODE, I don't know when it came out, but it has the same pan and most parts as a AOD.
Old Jun 26, 2012 | 07:26 PM
minnesotafisherman
What is an obvious way to determine whether this is an AOD or an AODE?
I have an AOD in my '92 2wd, and the 'Overdrive' gear is selected via shifting into it.
I would imagine on an AODE, it would be the Push Button overdrive at the end of the Shifter?
Thanks
P.S. mainly opting for going with the 4x4 Tranny because it only has 101K on it. My 2wd Tranny has almost 200K on it.
Old Jun 26, 2012 | 08:24 PM
SCRebel's Avatar
SCRebel
Yes. it should have some kind of O/D lockout button, if its AODE. By the way, if I am not badly mistaking, a AODE is also called a 4R70W.
When I rebuilt my AOD my Dad's friend had a parts AODE/4R70W that we took the input shafts out of a 6 clutch drums.
Old Jun 26, 2012 | 08:30 PM
minnesotafisherman
Ok, thanks Rebel.
Haven't checked with the seller yet, but I will get a hold of him. What if it turns out that this is an AODE/4R70W? Will it still be compatible?
Old Jun 26, 2012 | 08:48 PM
UNTAMND's Avatar
UNTAMND
Aode and 4r70 are not the same. Some internals are compatible but not all.
Progression was
Aod
Aode
4r70
From no electronics to all electronics.
The Aode really just uses electronics to engage overdrive that way you have 1-2-D(OD off button on dash) on the shifter VS 1-D-OD on aod where you really didn't have 2nd gear (unless you shift from 1 to D and immediately back to 1 to lock in 2nd)
4r70 has electronic pressure control and 3 solenoid packs for OD and converter lockup and something else.
Old Jun 26, 2012 | 09:24 PM
minnesotafisherman
Thanks for the info!
Just talked to the guy and confirmed that the trans is an AOD. The O/D select is in the Gear selector. Going to pick up the parts truck on Friday!
We are just going to source the correct rear driveshaft from a junkyard around here.
I will probably start a thread on the 4x4 conversion, and I will post a link to it here.
Thanks a lot for the help guys!
mattj
15
Jan 4, 2018 04:02 PM
Mrich69420
Jan 22, 2016 04:20 PM
daves302
Jun 4, 2011 10:06 AM
Dallenx
Sep 9, 2006 03:24 PM
factoryphil
Jun 5, 2006 11:44 AM
