Locking tailgate on 73-79 pickup
Old Jan 21, 2016 | 06:53 PM
Fgodbout's Avatar
Fgodbout
I'm looking for a way to lock my tailgate. I have a tonneau cover that locks, but if the tailgate can't then what's the point.
I can find a lot of locking handle for 87 and newer but I wonder if I'm the only one who tried to lock the tailgate on older model.
Thanks for your advice.
LMC and JCwhitney don't have anything
Old Jan 21, 2016 | 08:37 PM
dlburch's Avatar
dlburch
one option is to relocate the tailgate handle to the inside...
HANDLE RELOCATOR KIT TAIL GATE RELOCATES | F-43401-5 | NPD
Old Jan 21, 2016 | 08:55 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Any way you can add an end edge or bracket to the cover to catch the tailgate when the cover is closed?
Or you can add the seat belt latch trick on the inside of the tailgate or use a barrel bolt set up on the inside.
Yes kinda redneck, but there are fancier fence/gate latch set ups.
Old Jan 21, 2016 | 09:21 PM
Fgodbout's Avatar
Fgodbout
I might have to fix it the redneck way. I was hoping to find something with a key or something like that. Thanks for the suggestions, it's appreciated.
Old Jan 21, 2016 | 09:23 PM
Fgodbout's Avatar
Fgodbout
The idea is good, but I'll have a problem as I need to open the tailgate to get to my tonneau cover latch. Once the tailgate up, nobody will have access!!!
Old Jan 21, 2016 | 10:44 PM
77&79F250's Avatar
77&79F250
Well take a newer truck key style handle set up from a JY truck and graft it into your current tailgate set up.
Only takes locating one then a sawzall, cut off wheel, grinder, welder, some body work and paint.
Old Jan 21, 2016 | 11:48 PM
greentruck72's Avatar
greentruck72
my buddy built a second tailgate inside the bed so all you do is open the regular tail gate then have a bolt lock or padlock holding the second tailgate shut looks normal from the outside, it would add a layer of security as well.
Old Jan 22, 2016 | 07:26 AM
77&79F250's Avatar
77&79F250
Get a hold of this guy and see where he got his bed cover, it has that lip that will hold the tailgate shut and then key lock the cover.
https://www.ford-trucks.com/forums/1...-brackets.html
F100Mann
18
Jul 16, 2013 08:59 AM
ridgerider3
May 30, 2009 06:22 PM
Kanuck
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Oct 9, 2007 06:08 AM
hood
1997 - 2003 F150
Dec 12, 2003 07:20 AM
