Sponsored by: Real Truck
Folding key fob
Old Jan 20, 2016 | 11:20 AM
Wormwood's Avatar
Wormwood
Folding key fob
I've search around here & the internet for an aftermarket key that might be sliding or folding, anything trying to reduce the size of the key fob.
Does anyone know of a company doing this?
Thanks,
Wormwood
Old Jan 20, 2016 | 11:27 AM
MadWolf's Avatar
MadWolf
You could probably eliminate the key fob all together, if you wanted to. By now, I imagine there's a few high end security systems that will open your doors, and start the truck for you, right from your smartphone app.
Old Jan 20, 2016 | 12:09 PM
Bugzilla46310's Avatar
Bugzilla46310
Thanks,
Wormwood
Not to be a sxxxx axx, but Ford uses them for the Fusion, at least on my 2016 Fusion.
Old Jan 20, 2016 | 06:34 PM
ligito's Avatar
ligito
https://www.google.com/webhp?sourcei...olding+key+fob
Old Jan 20, 2016 | 08:11 PM
Just Strokin's Avatar
Just Strokin
Not sure the Fusion folding fob will work. It has a different FCC ID than the Super Duty remote entry uses.
I have done some experimenting on this issue. I have purchased a folding key for my 2105 that has the transponder chip and the remote entry buttons. So far, I have got the transponder to program. It has to be the 80bit chip ID - 4D63 80 Bit Transponder Chip. The 4D60 Transponder chip will NOT work.
The FCC ID for the remote entry needs to be CWTWB1U212 or CWTWB1U322 or GQ43VT11T. The folding keys with this FCC ID I have received will not program for the door locks. I have a separate remote entry fob like you see before the IKT's that has these ID's and it will program and work.
I current use a standard 80 bit SA key and the fob in the photo instead of the IKT since I have the bi-directional remote start also
Hope this helps you with your search for a folding key fob
toys4dlr
Sep 21, 2024 06:44 AM
90pioneer
6.7L Power Stroke Diesel
17
Apr 23, 2024 03:10 PM
1911fan
Jun 22, 2017 09:55 PM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
DEMIGOD
20
Feb 4, 2014 07:56 AM
