Low oil temp
Old Jan 20, 2016 | 09:57 AM
Kdawg89's Avatar
Kdawg89
Low oil temp
Hi all,
I was driving down the freeway this morning and all of the sudden my oil temp started jumping around really quickly and now it has dropped to about 165 with coolant temp at 190. I am guessing the temp sensor has likely gone bad. Anything else I should check first, I just can't imagine my oil is actually only 165 degrees going down the freeway.
Old Jan 20, 2016 | 10:08 AM
Jmoen7's Avatar
Jmoen7
Only way your oil will be colder than your coolant is if the thermostat is stuck or you have a BPD air-oil cooler. But with your jumping erratic temperature i would recommend check the pigtail/connector and the sensor itself. Sensors are cheap
Old Jan 20, 2016 | 10:15 AM
Kdawg89's Avatar
Kdawg89
Yeah that was my thoughts too, do you happen to know where the oil temp sensor is?
Old Jan 20, 2016 | 10:34 AM
Kdawg89's Avatar
Kdawg89
Now all of the sudden after a couple restarts of the motor and jiggling the harness its reading over 190 again, so definitely something sensor or harness related.
Old Jan 20, 2016 | 11:33 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
If I recall, someone found a chaffed wire on the oil temp sensor a few years ago. He found it a few inches into the harness from the sensor. By the way, your ECT sensor and EOT sensors are the same and can be swapped for testing.
2006powerstroke90
Dec 4, 2016 09:40 PM
dizzyfingers03
Mar 21, 2014 02:22 PM
blueline970
Jul 13, 2012 10:11 PM
AZwhite350
Mar 11, 2012 11:47 AM
03_PSD
15
Jan 21, 2010 01:22 PM
