Oil Temperature Location
Old Mar 20, 2014 | 06:20 PM
dizzyfingers03's Avatar
dizzyfingers03
I just ordered one of these to go in the beast. I'm planning to upgrade power soon, but I wanted some baselines before hand (it's the engineer in me). Anyway, since it has the temperature sensor and my truck is a manual, I was thinking either coolant or oil temperature. Obviously, oil is a better one to monitor, but I couldn't think of where to tap in for the sensor. So, has anyone ever installed an oil temperature sensor, and if so, where? Thanks.
Old Mar 20, 2014 | 08:56 PM
ReBilld's Avatar
ReBilld
I'm not sure where you could put an oil temp sensor Nick. It should be after the oil cooler, and you can't remove the factory oil temp sensor cause it has to report to the PCM. I'll look tomorrow at one of the engines in my shop and see if I can see a place for one and let you know if i find anything.
Old Mar 21, 2014 | 04:48 AM
dizzyfingers03
Thanks. I'll do some digging. Maybe I'll just end up tapping the coolant if I/we can't come up with something.
Old Mar 21, 2014 | 05:00 AM
madpogue's Avatar
madpogue
I'd go with engine temp, and use the spot where the sender is for the lame OEM dash gauge. You can always get an Interceptor or other device that communicates with the PCM for oil temp.
Old Mar 21, 2014 | 05:07 AM
dizzyfingers03
Yeah, that would be easy enough to do with a T fitting. Or just unplug the crappy dash one and leave it hang (actually had to do that on the Ranger since it was already broken).
Old Mar 21, 2014 | 09:38 AM
farmert's Avatar
farmert
There is a plug in the oil filter adapter I used for the oil temp gauge in the 97. It is just above the filter IIRR. It is the brass plug in this pic. http://www.ebay.com/itm/1999-2003-7-3L-Powerstroke-Diesel-OEM-Ford-Oil-Cooler-Filter-Adaptor-F81Z6881BA-/231134267131?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d0ad06fb&vxp=mtr#ht_370wt_610
Old Mar 21, 2014 | 02:22 PM
dizzyfingers03
Originally Posted by farmert
There is a plug in the oil filter adapter I used for the oil temp gauge in the 97. It is just above the filter IIRR. It is the brass plug in this pic. 1999 2003 7 3L Powerstroke Diesel Ford Oil Cooler Filter Adaptor F81Z6881BA | eBay
Thanks for the information. I will have to look for that this weekend.
rechinca
May 14, 2017 10:24 AM
friskyjake
Mar 20, 2017 02:21 PM
Kdawg89
Jan 20, 2016 11:33 AM
blueline970
Jul 13, 2012 10:11 PM
twg1966
Jun 12, 2006 05:13 PM
