Engine oil temp
Old Mar 11, 2012 | 12:53 AM
AZwhite350's Avatar
AZwhite350
Engine oil temp
I have the ELM bluetooth OBD sensor and I use a Droid smartphone with it. My question is - does the 6.0 have a sensor to measure engine oil temp. I am getting a read that does not vary from 32 F. I can easily get the FICM voltage, rpm, coolant temp, etc, but have not been able to get the engine oil temp.
Old Mar 11, 2012 | 01:03 AM
Dieselpop's Avatar
Dieselpop
Yes, my EOT runs about 200* and my ECT runs about 194*
pop
Old Mar 11, 2012 | 01:11 AM
AZwhite350's Avatar
AZwhite350
Damn, my sensor must be bad. Wouldn't it throw a code if the sensor was bad?
Old Mar 11, 2012 | 01:14 AM
BLADE35's Avatar
BLADE35
Maybe its a Bad EOT Sensor IDK
AmDriven2liv (Sean) has that blue tooth droid phone app or something like that he might be able to give some help on it
Do you have to program anything in it to get a certain gauge or just plug n play maybe try to reset it IDK thinking out loud
Old Mar 11, 2012 | 11:47 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Check the PID settings:
EOT
PID: 221310
Unit: Deg. F
Max/Min: 300/0
Equation: ((((A*256)+B)/100)-40)*(9/5)+32
Make sure you have the correct amount of these ( in bold. And, they are in the right places. I couldn't get mine to work, and found I had too many!!!
akblackfoot
Jan 8, 2017 07:03 PM
Steven Stocki
Dec 10, 2016 09:23 PM
Kdawg89
Jan 20, 2016 11:33 AM
Tuff48
21
Oct 10, 2015 08:08 PM
caseydudem
21
Jan 15, 2008 07:14 AM
