Sponsored by: Real Truck
edge systems
Old Aug 12, 2003 | 06:49 PM
  #61
Overkill's Avatar
Overkill
FTE *******
edge systems
Originally posted by tankhead
Marty,
What do u mean by wheel travel? U said one time I should have approximately 12" of useable wheel travel w/ the 8" lift and 37" PJ's on 17x9 M/T II's.
Wheel travel refers to the actual amount of vertical movement of the suspension. The true technical term for this is jounce.
Old Aug 12, 2003 | 06:55 PM
  #62
Overkill's Avatar
Overkill
FTE *******
edge systems
No but seriously, see some of the problems I ran into and feel good, and literally thankful, about rewarding Donahoe Racing w/ a purchase on my lift kit and other goodies for not forgettin about us early 99 users.
It's only fair to mention that the Edge adjustable pan rod will not work with early 99s due to the small lower track bar mount.
Old Aug 12, 2003 | 07:05 PM
  #63
Overkill's Avatar
Overkill
FTE *******
edge systems
[QUOTE]Originally posted by abendx
[B]
Because when you invest 30-50K on a truck it doesn't make sense to skimp on something that can quite literally make or break your truck. Again, you are talking about a difference of less than 1%. [/img]
Old Aug 12, 2003 | 07:17 PM
  #64
Overkill's Avatar
Overkill
FTE *******
edge systems
my point is that you guys could be getting just as much suspension as you'll ever need for a lot less money!
With which kit specifically?
ProComp?
Fabtech?
Superlift?
Skyjacker?
Rancho?
Truckin Suspension?
Old Aug 12, 2003 | 07:27 PM
  #65
DCSpecial's Avatar
DCSpecial
edge systems
ProComp?
Fabtech?
Superlift?
Skyjacker?
Rancho?
Truckin Suspension?
And I thought that for sure Truckin' was the way to go since it is probably the cheapest available..........and I'd get just the same amount of lift and keep alot more cash in my pocket
Old Aug 12, 2003 | 08:28 PM
  #66
Streetcruzer's Avatar
Streetcruzer
edge systems
ProComp?
Fabtech?
Superlift?
Skyjacker?
Rancho?
Truckin Suspension?
Well, we could lift the bar (equal quality product?) a little higher and add:
RCD
BDS
After EDGE, Donahoe rated these #2 and #3 in a previous thread!
Still looking,
Lenny
Old Aug 12, 2003 | 08:32 PM
  #67
Scratch's Avatar
Scratch
edge systems
RCD
BDS:
Anyone have contact info for either of these companies?
BTW MY local shop has never heard of Edge lifts.
Bob
Old Aug 12, 2003 | 08:53 PM
  #68
DCSpecial's Avatar
DCSpecial
edge systems
Bob
Try:
www.racecardynamics.com
www.bds-suspension.com
Many people haven't heard of Edge lifts, the bigger shops out here have, not sure about the smaller ones though.
Hope this helps.
And oddly enough RCD and BDS which Donahoe ranked 2 and 3 don't seem to be as popular as some of the other brands (SJ, SL, and ProComp)..............I probably guess advertising has something to do with that.
Old Aug 12, 2003 | 10:54 PM
  #69
RRMike's Avatar
RRMike
edge systems
Actually the track bar brackets and u-bolts are different.
As is the pitman arm.
Old Aug 13, 2003 | 10:41 AM
  #70
Overkill's Avatar
Overkill
FTE *******
edge systems
RCD
BDS
Still looking,
Lenny
I left RCD off the list because their kits are actually more expensive than Edge. Although their SD kits are not quite as good they do have a great product line. I sell quite a few of their F150 & Chevy IFS kits and will soon be distributing them.
I forgot BDS (Trailmaster) because I've never installed one of their SD spring kits. However just by looking at their kit it is obvious that they are not as well constructed and I would bet the price of a kit that it will not ride as well as an Edge lift.
Old Aug 13, 2003 | 12:15 PM
  #71
Scratch's Avatar
Scratch
edge systems
anyone know what the bed rail height is with 35s and edge 6", edge 4.5, and 4.5\ minipaks?
BOb
Old Aug 15, 2003 | 12:23 PM
  #72
Streetcruzer
edge systems
BOb
I am curious about these measurements also, as I still need the truck to fit through the garage door. (oversize door)
Thanks,
Lenny
Old Aug 15, 2003 | 12:35 PM
  #73
V-104Me's Avatar
V-104Me
edge systems
58.75" to of bed rail over the axle. see sig.
Old Aug 15, 2003 | 02:59 PM
  #74
Uptown83's Avatar
Uptown83
edge systems
I measured from the ground to the top of bed at the back and measured 61 inches and i have a 4" procomp (aka procrap) with 315's
Old Nov 28, 2003 | 09:05 PM
  #75
izzi's Avatar
izzi
edge systems
i decided on the 6" edge. overkill offroad in plano is doing it .
is this the same overkill?
i figure if i go taller later, i would rather buy used hangers than used springs. the 6" lift will really look rockin' with those 265's
mike
