6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGT's
Old Jan 18, 2016 | 11:41 AM
ginomachino's Avatar
ginomachino
EGT's
What is the general, rule of thumb egt scale for different conditions (no/light/medium/heavy towing)? As in, what is the low range, medium tuned range, safe red line, and cooking the motor points?
Old Jan 18, 2016 | 01:15 PM
UGA33's Avatar
UGA33
Anything over sustained 1250-1300* is asking for trouble no matter what you are doing. At the strip, my 6.4 would do short bursts of 15-1600*. Cruising empty on the interstate was 7-800*. This was tuned running Spartan 275 tune for most of its life. Towing heavy was 9-1100*.
Old Jan 18, 2016 | 07:37 PM
73fan's Avatar
73fan
I have mine tuned with H&S. Normal driving I will not see it go above 800. That's driving easy though, and empty. The highest I have ever seen it was 1,100 and that was heavy towing up a long steep grade.
Old Jan 19, 2016 | 11:07 AM
ginomachino
OK, I was towing a basically empty enclosed 18ft trailer and was seeing 750 to 860 temps. I knew it wasnt anything to worry about, but really wanted to know the threshold. Thanks
Old Jan 20, 2016 | 06:38 PM
CrazySob's Avatar
CrazySob
You should see anywhere from 600-700 cruising at 65 unloaded (It depends on tunes and how much fuel they push) and shouldn't be running anything over 1200 for extended periods of time. The limit that most agree on is 1450 (roughly the same as a 6.0, but remember our pistons are very delicate compared to a 6.0) for very short bursts.
Most canned H&S tunes will defuel right around 1100-1200*.
danr1707
Aug 19, 2017 03:59 PM
firedaniel
Jul 31, 2011 09:50 AM
952X4
Aug 3, 2009 08:00 PM
whattatruck250
Aug 5, 2007 10:52 AM
dgarzoli
May 5, 2005 07:14 PM
