EGT's?
Old Aug 3, 2009 | 11:57 AM
952X4's Avatar
952X4
EGT's?
Just got my pyrometer installed.. What temps should I be seeing for average driving and for heavy towing?
Old Aug 3, 2009 | 12:00 PM
Brown Falcon's Avatar
Brown Falcon
Depends on the truck and what mods you have... keep it under 1200 and you'll be fine.
Old Aug 3, 2009 | 12:22 PM
superduty4x4's Avatar
superduty4x4
I usually see around 600 cruising at highway speeds. Towing it gets a tad hotter but not much unless I'm pulling a grade.
Old Aug 3, 2009 | 12:52 PM
Brown Falcon
If you are getting high numbers or tow a lot you might want to look into a intercooler setup.
Old Aug 3, 2009 | 02:48 PM
aaron ford's Avatar
aaron ford
400 idle, 600 cruise. 1100 at 20 psi on a hard pull empty. I see 1250 on a hard pull with trailer. When I had a boost leak, I would idle at 600, cruise at 800 and go to 1100 at 5 psi boost (mild pull).
HTH
Aaron
Old Aug 3, 2009 | 03:26 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Like previously said alot is going to depend on what all has been done to your truck, but more importantly how you drive it. With a heavy load I can pull a hill in 5th gear around 12-1300 rpms, or I can loose about 5-10 mph go to 4th and stay around 1100. A IC is sitting in the shed, just need time to install it. Same can be said for empty too, too high of a gear will really jack up the EGT's
Old Aug 3, 2009 | 03:38 PM
952X4's Avatar
952X4
I always downshift to 4th when pulling up a tough grade, I like to keep the revs up and not bog the motor down...I've been thinking about an intercooler but don't know what it would cost to get one or how hard they are to install...
Old Aug 3, 2009 | 08:00 PM
79_250RangerLariat
You can find them cheap on ebay, or sometimes on here. Same with the tubes, a little modding to make them fit but it isn't bad. The Spyder can be bought new from Ford, I think it's around $125 but I don't remeber
