Leak question
Old Jan 18, 2016 | 08:41 AM
watty1010's Avatar
watty1010
Leak question
Hey all. I recently returned from picking up my excursion 1200 miles away. It did great on the trip. No leaks at all the last three days First night home and I woke up to a leak. I haven't had a chance to look at it yet because it is 8 degrees out right now. This might be the first time the truck has seen cold like this. Any of you have any suggestions of what it could be. I plugged it in last night for the first time. The leak looks to becoming from the front Could it be a result of that? I'm a novice so just looking for help. 01 7.3 140k
Old Jan 18, 2016 | 09:43 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Let's start with kind of fluid is it ?
Leaking water into the cab ?
Leaking water out of the cooling system ?
Leaking ATF ?
Leaking leaking gear oil ?
Leaking motor oil ?
Old Jan 18, 2016 | 09:46 AM
harley4jcs's Avatar
harley4jcs
There are SEVERAL fluids that it takes to move a truck. It might be VERY HELPFUL to ID what fluid has escaped.
Old Jan 18, 2016 | 09:48 AM
harley4jcs's Avatar
harley4jcs
Leaking ATF ?
Leaking motor oil ?
Power steering ?
Brake ?
oil cooler?
washer bottle?
Old Jan 18, 2016 | 09:52 AM
pirate4x4_camo
Just so we don't leave any out
Battery acid
A/C condensation
Diesel fuel
El_Coqui's Avatar
El_Coqui
Hi watty1010 congrats on getting your Ex home! I'm tracking an oil leak on my 7.3 as well but I'll share what I've learned and been helped with so far.
I see you mention it coming from the front of the motor. I know it's cold out outside at 8 degrees but if you could take a peek under the truck that would help pinpoint possible locations. If it's coming down the front side I think you may need to take a look at the hpop(high pressure oil pump). The fittings on the lines there have a tendency to back off over time. Another point on the hpop is the "non-serviceable" plug on the bottom of it. http://www.riffraffdiesel.com/serviceable-long-threaded-hpop-plug/ the plug in this link will take care of that potential leak point.
If, however, when you look underneath the truck and leak appears to be coming from the weep hole between the transmission and the oil pan there are at least 2 potential leak points. The first is the o rings on the turbo pedestal. The other one would be the EBPV...it's another common leak point on out 7.3. That involves either plugging the the spot on your pedestal where that ebpv rod attaches and I think removing the rod....or you can do like I chose to and replace the pedestal with the non ebpv one. http://www.riffraffdiesel.com/garrett-non-ebpv-blank-pedestal-99-5-03/
Anyways...that's my limited knowledge on what it possibly could be. I'm sure one of the other guys will be along and can refine and add to or fix what I've found so far.
Welcome to FTE
Old Jan 18, 2016 | 10:59 AM
watty1010's Avatar
watty1010
So I braved the cold and in looks to be green. So I guess it would have to be coolant. It looks to be coming from the hose. Here is a pic
Old Jan 18, 2016 | 11:19 AM
howler4x4's Avatar
howler4x4
Try to tighten the clamp.
If this is indeed the 1st time this truck has seen single digit temps then it could be that simple and the others could be loose as well. Hand tight, not Hulk tight.
Old Jan 18, 2016 | 11:50 AM
pirate4x4_camo
Looks like somebody replaced the factory spring clamp with a worm drive clamp.
Possibly because it was leaking and they thought more clamping was going to fix it.
If I had to guess I would say a crack in the plastic outlet of the radiator.
Old Jan 18, 2016 | 12:06 PM
watty1010's Avatar
watty1010
That doesn't sound good
Old Jan 18, 2016 | 12:23 PM
Oldguyfl's Avatar
Oldguyfl
Maybe they just replaced the hose and clamps. Did not bother with the factory clamps.
Tighten it and see if it still leaks
Old Jan 18, 2016 | 12:38 PM
pirate4x4_camo
Luckily radiators are fairly inexpensive.
Either way, if it was mine I would take the oppertunity to do some maintence and back flush the system and change to ELC coolant, install new hoses and switch back to a spring clamp.
Old Jan 18, 2016 | 02:22 PM
kcbhiw's Avatar
kcbhiw
Before replacing the radiator, have a look further up. The degas bottles tend to crack along the bottom and coolant will run down the radiator on that side of the truck. It could be as simple as replacing that bottle. Such was the case on my Ex.
Old Jan 18, 2016 | 10:33 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Good responses so far for you Watty. The radiators have plastic caps on the top and bottom with plastic inlet and outlet. They do crack after as many years as we have on our trucks. Mine cracked on top. Leaked fluid EVERYWHERE while pulling a buddy's 5th wheel. I went with an all aluminum replacement so I would not have to ever worry about it again. Like kcb said, check the degas bottle for cracks on the bottom first.
If you will keep the green coolant, you will need to be diligent about checking it periodically with the test strips. Many of us have switched to the red ELC (CAT/EC-1 rated) coolant that does not need test strips. Many threads on that in the 7.3L forum.
CobraBern
Dec 17, 2010 07:39 PM
mttsood
1997 - 2003 F150
Apr 15, 2010 06:27 PM
DCFord
16
Mar 7, 2010 02:35 PM
mexemo
Sep 17, 2008 04:40 PM
ustolemycupcake
Mar 3, 2005 07:31 AM
