Help With Leak???
Old Dec 14, 2010 | 05:20 PM
CobraBern's Avatar
CobraBern
Help With Leak???
I have a leak and it seem to be coming from the driver side on the front right off of the frame rail, The are some fittings there and the leak started out small and it is getting bigger and bigger. What can it be? Let me so that i know what i am looking for.
Old Dec 14, 2010 | 05:33 PM
rbaker6336's Avatar
rbaker6336
Is it an oil leak?Sounds to be in the area of the oil cooler
As the weather gets colder the oil coolers are know to start leaking
Old Dec 14, 2010 | 11:57 PM
CobraBern's Avatar
CobraBern
What do i need to do to stop the leak? Do i need to tighten the fittings?
Old Dec 15, 2010 | 12:01 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Sounds like power steering to me.
Old Dec 15, 2010 | 05:16 AM
bcaughhorn's Avatar
bcaughhorn
a pic would help
Old Dec 15, 2010 | 03:58 PM
CobraBern's Avatar
CobraBern
I will get some pics up tonight.
Old Dec 15, 2010 | 10:49 PM
CobraBern's Avatar
CobraBern
Well guys here are the pics. Thanks for the help.
Old Dec 15, 2010 | 10:51 PM
Waltdog's Avatar
Waltdog
of American machinists
Can you tell what color the fluid is? Have you checked the level of fluid in the brake reservoir, and power steering reservoir?
Power steering leak will be red (its ATF)
Old Dec 15, 2010 | 11:19 PM
CobraBern's Avatar
CobraBern
I am pretty sure it is red.
Old Dec 15, 2010 | 11:39 PM
Waltdog's Avatar
Waltdog
Ok so if the fluid is red you are prob dealing with a power steering leak. You can try to tighten the fittings however it may not help. What you are seeing is the early stages of a hose failure. Best coarse of action would be to determine what hose is leaking (wrap suspected leak area in white cloth) then simply remove and replace. There are two hose that could be leaking,when it happened on my truck I replaced them both.
Replacing the hoses is not bad: Remove battery/ Air filter and inter cooler pipe for better access to the hoses, when complete a good flush with a high quality synthetic ATF will help smooth thing out a bit. Ill try to find the link on flushing power steering system
Old Dec 17, 2010 | 04:37 PM
CobraBern's Avatar
CobraBern
Alright guys i looked a little closer and come to find it is motor oil. What else can i look for in order to find the leak?
Old Dec 17, 2010 | 07:39 PM
cavitation's Avatar
cavitation
I am thinking it might be CCV oil seepage/drip from the bottom of the CAC boot (the blue rubber boot). I had some motor oil on the frame in that area as well. Before I did the CCV mod I had seepage at the bottom of the boot which is above the frame area. Run your hand along the underside of the boot and see if motor oil comes off.
