Defueling symptoms?
Old Jan 15, 2016 | 08:45 PM
Davidp76006's Avatar
Davidp76006
Defueling symptoms?
I have a 2002 that has a 6 position chip. When going from a stop and stepping on the gas pretty good it feels as if the tranny is trying to slip and after I let off the gas pedal it has a rough idle. Are those 2 things related to defueling?
Old Jan 16, 2016 | 06:26 AM
Tugly's Avatar
Tugly
Defueling is an occurrence at WOT at 2800 RPM, and this greatly diminishes the ability to get speeds much over 80 MPH D with a stock tune on 3.73 differentials. A rough idle right after using the throttle as a switch instead of a fader is usually a sign of the IPR and HPOP playing a game of catch-up (particularly with a hot tune). It's also possible part of your system is putting air in your oil or fuel, and this can cause a symptom you describe.
sdawe
Dec 29, 2023 01:15 AM
rwinsouthla
Sep 30, 2012 01:41 AM
Mike8623
Aug 2, 2011 12:52 PM
blueovalbigblock
Nov 22, 2010 09:48 AM
zoti
1983 - 2012 Ranger & B-Series
Dec 21, 2003 08:14 PM
