two hopefully minor issues here....
Old Sep 28, 2012 | 12:24 PM
rwinsouthla's Avatar
rwinsouthla
Newbie here with two hopefully minor issues you guys may be able to help with. The first issue is my 2006 Expedition XLT 5.4L idles at just below 500 rpm. Sometimes, with the AC on, it goes a tick lower and bobbles between 425 or so and 500 and just feels like it will stall on me. What should it idle at and how to increase the idle?
Second question is my gas pedal, but that's not really it. When I push the gas pedal, i know it pushes a linkage to increase the fuel delivery to make it accelerate. Up until 5000 miles ago or so, it was a smooth acceleration, smooth pedal, and I could feather it down ever so lightly when I accelerated from a stop. Now, I have to push the pedal down 1-2 inches prior to any response. I feel like it is a linkage issue between the pedal and the throttle linkage, but am unsure. Is there somewhere I can shoot some WD-40 and if so, where?
Thanks in advance, ray
Old Sep 28, 2012 | 10:54 PM
teamlx88's Avatar
teamlx88
Sounds like it may be time for a new throttle position sensor and a iac cleaning
Old Sep 29, 2012 | 12:28 AM
rwinsouthla
Thanks for the reply. I've now been educated on the TPS. Can you tell me what IAC is?
Old Sep 29, 2012 | 10:55 AM
teamlx88's Avatar
teamlx88
Idle air control. It's a small valve that controls engine idle. When it gets dirty the truck starts to idle freaky
Old Sep 29, 2012 | 11:18 AM
lv2race's Avatar
lv2race
Your '06 doesn't have an IAC. Did you check for codes?
Old Sep 29, 2012 | 10:36 PM
rwinsouthla
No. I didn't check the codes. The check engine light is not on.
Old Sep 30, 2012 | 01:41 AM
alloro's Avatar
alloro
There are codes (regular and pending) that can be set without turning on the CEL.
Fuzzydog
Jul 27, 2018 09:24 AM
jstihl
Dec 23, 2017 08:18 PM
acf6
Feb 3, 2014 10:56 PM
Redneckmorton
Dec 14, 2012 10:51 PM
GreatWhite99
Feb 18, 2009 06:17 PM
