7.3 engine build advice
Old Jan 15, 2016 | 12:28 PM
Meydawg51's Avatar
Meydawg51
I'm currently in the process of stripping down the 7.3 block and heads to be sent to the machine shop to me decked surfaced and vatted
I'm shooting for a 550hp to 600 hp engine. I'll be adding
Stage 2 injectors
Arp head studs
Melling lpop
Aftermarket hpop
Regulated fuel return
Built stock turbo (360 bearings, 1.00 ar housing, ported intake housing, wheel, adjustable waste gate.)
EBPV delete
Non EBPV petistol
High flow turbo outlet
Intake heater delete
6.0 trans cooler
I'll also he reusing the stock forges rods.
My question would be what other parts would be nessasary or recommended and what other advice you might have for this build?
Old Jan 15, 2016 | 11:25 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'm no expert but that HP level is never gonna happen with a stock turbo. Probably need hybrid injectors. People recommend fire rings for HP builds once the heads have been removed. And quality tuning matched to your mods and use for the truck.
600 hp will not be cheap.
There's some stuff to google until more knowledgeable members come along.
Old Jan 15, 2016 | 11:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
This appears to be a duplicate thread of the thread below...
https://www.ford-trucks.com/forums/1...ld-advice.html
Fordman96
209
Dec 7, 2018 09:51 PM
Meydawg51
17
Jul 17, 2016 01:16 AM
valiant500hp
Apr 24, 2012 03:33 AM
JOHN2001
Jan 11, 2012 12:15 AM
bigtorque
Nov 22, 2006 07:10 AM
