6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
weird cruise control problem
Old Jan 15, 2016 | 07:49 AM
ginomachino's Avatar
ginomachino
using cruise control going about 70mph, when I go over rough bridge joints, the cruise control backs off the throttle a lot. Sometimes, it gets stuck in a weird on-off loop and i have to turn the cruise control off then back on and it's fine. if I give it throttle while in the loop it accelerates fine, but I think it returns to the stumble like condition. I say "I think it returns" is because I only experimented with accelerating while it's doing it only once, and just enough throttle to get it off the deceleration, and as soon as i let off the pedal, it went back to doing it so i tapped the brake pedal, set cruise again and it was fine. But it does do it on the harder bumps, the ones that make the suspension vibrate. if it is smooth enough for the tires and shocks to handle, it's fine
Old Jan 15, 2016 | 09:51 AM
sxrfun's Avatar
sxrfun
You're most likely experiencing some wheel hop in the rear end on larger bumps which is causing the wheel speed sensors to have messed up readings and de activating/messing up the cruise control.
Old Jan 15, 2016 | 10:27 AM
ginomachino
I kind of came to that conclusion myself, and figured I would ask here if anyone else is experiencing the same effects
Old Jan 15, 2016 | 07:19 PM
eberlestock's Avatar
eberlestock
I agree with xsfun.. Might be time for new shocks or less air in the tires
cghstrojan08
1997 - 2003 F150
Mar 2, 2009 06:59 AM
4montecarlo
Sep 18, 2007 03:08 AM
silverxlt
2004 - 2008 F150
Mar 3, 2006 08:36 PM
lovethosediesels
Jan 5, 2006 07:51 PM
