I work in a seasonal job. I sit at home just thinking what I need to do to my truck. Well I always look at parts and do a lot of reading on here. I'm getting a itch to go back to my Hedman Header that I have just sitting on my garage wall like a trophy. I would do it way different this time around when I first had the header I was younger and didn't know much.
If I were to go header route I think I would get the header powder coated and also I remember having a small leak so I think I would split them down the middle. Also was looking at a newer carburetor I've had my eye on it since AB posted it Quick Fuels HR 450 CFM Mechanical Secondaries.
My race cars use headers.
All my street and street/strip cars use cast iron EFI exhaust manifolds.
Durable.
Inexpensive.
Efficient.
You will need to drive a mechanical secondary carb with great restraint to keep from getting the fuel economy of a V8.
I realize that. I don't daily drive this truck it only comes out every other weekend in the spring/summer time goes to car shows things like that and sits in the garage as soon as it gets cold.
Heh, a few weeks ago, I drove for 100 miles to my parents house in 5 degree weather with a blown power valve and a bad float at 70mph and still got better gas mileage than my brother's 351.
Even with 32" tires, I think I'd have to cut a hole in my fuel line to get it down into single digit fuel mileage.
If I were to get one (which I am still thinking about), I'd get QuickFuel's 450 that uses the vacuum secondaries.
They don't have it listed on their site, but there is also a coated one that looks intriguing.
That one is almost like my 470 truck avenger carb. I'm anxious to see how it runs. I didn't know it had a second metering block until my brother-in-law told me, it's not adjustable though. It should perform quite well.
On the c series intake does it really matter if the primaries are facing forward or towards the back?
Yeah, I have a 465cfm on mine and it's great. But I can't help but just crave the insane tuneability of the QF.
And yes, the C series doesn't care what direction the carb is facing. The only reason it matters on the DP is simply due to having specific runners for primaries and secondaries. The carb needs to be oriented correctly so that the primaries go in the primary runners, and secondaries into the secondary runners. On the C-series, it's one big opening so orientation is completely irrelevant.
I know dude me too!! I saw videos on how it's way different then a Holley. The thing that made me want mechanical secondaries is a friend of mine has a chevy 307 and we change his cam, intake, and carburetor this past summer. He happen to have a Holley 600cfm double pumper mechanical secondaries. I was amazed I didn't know there was such thing and the way the engine revved when the secondaries opened. All I could imagine is that what if that carb was on my truck (of course in a smaller CFM rating).
