2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2013 Expedition LED Conversion
Old Jan 11, 2016 | 07:18 PM
CoachMikeSC's Avatar
CoachMikeSC
Just converted to all LEDs (Including the Headlights). Here are some pictures.
Got most of the bulbs from Amazon but had some trouble finding the puddle lights.
I saw many instances where people had cut open the Ford OEM Puddle Lights (part number 3F1Z-13B375-AA) and had replaced the bulb with and LED. I was able to find a place that makes OEM type replacements with LEDs. You can see them here.
Old Jan 17, 2016 | 12:49 PM
berry1234's Avatar
berry1234
Looks good! Do you have the bulb numbers for the reverse lights?
Old Jan 17, 2016 | 02:13 PM
CoachMikeSC
Thanks bro...these are the ones I bought...
Amazon.com: JDM ASTAR Extremely Bright Max 50W High Power 912 921 T10/T15 LED Backup Reverse LightS,Parking lights, Xenon White: Automotive Amazon.com: JDM ASTAR Extremely Bright Max 50W High Power 912 921 T10/T15 LED Backup Reverse LightS,Parking lights, Xenon White: Automotive
Old Jan 19, 2016 | 10:14 AM
berry1234's Avatar
berry1234
Awesome, thanks! I assume these really light things up behind you while backing up?
Also, did you replace the driving/fog lights with LED's too?
Old Jan 19, 2016 | 10:44 AM
CoachMikeSC
Take a look at this photo again for comparison
LED on near side and standard bulb on far side.
I did the whole truck inside and out with the exception of the high back brake light. The design of that light requires a bulb that is EXACTLY the same dimensions of the incandescent bulb and I haven't found an LED that was made that way yet.
Here's a list of everything I bought along with notes for where they go:
http://amzn.com/w/GGMEKE6H7YNP
The ones I used for the Fog lamps are "plasma" LEDs and I'm not sure that they really hit the focal point of the reflector as well as a point source light. I may change them to a different type...still debating...
Old Jan 19, 2016 | 03:57 PM
berry1234's Avatar
berry1234
Ah, missed that. Way brighter on the backup bulbs. I have done all interior bulbs and license plate bulbs. Next prob. backup, tail light.
Thanks again for the info.
Old Jan 20, 2016 | 07:24 AM
alwaysfords41's Avatar
alwaysfords41
What were the 'slight mods' you mention on the Amazon list for the headlight bulbs? Also if I'm reading this correctly, they are 6K out of the box but come with a film to alter the output color. Did you leave them stock or film them?
Old Jan 20, 2016 | 08:09 AM
sailfish86's Avatar
sailfish86
How did the LED headlights affect the drl's. I found a set I would like to get for my 2008 Expy and they said not to use if you have drl's. The kit is from Vled.com
Dawgfever
Jan 2, 2019 10:58 AM
mtondreo
Dec 23, 2009 06:26 AM
thenewjohndeere
1978 - 1996 Big Bronco
Dec 29, 2006 10:07 AM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 6, 2004 02:26 AM
