95 e350 7.3 interior lighting issues
Old Jan 10, 2016 | 10:09 AM
67camaro's Avatar
67camaro
Not sure where to start looking
The cargo Van was used by the Fire dept
They must of disabled the door switches to activate the lights as well as the headlight control switch [ it clicks if you turn it left ]
Now I hooked up the door buzzer and the sound goes off if you depress the door switch so they work [ its annoying disconnected it ]
The bulbs were replaced
There are 3 lights in the overhead
Not sure if a fuse was removed and where it goes if that is the issue
Where would I locate this to replace it
Option should I just wire my on switch Would this be less work
Old Jan 10, 2016 | 02:47 PM
blageurt's Avatar
blageurt
You need a Auto Electric guy ( 12 V expert ) I have the Factory Drawings ..But If it was x Fire you might need to contact the Outfitter for their Diagram ......I use a Multimeter and a Probe...and use my Factory Book...It is Impossible to Diagnose Electric Chit online....Good Luck
Old Jan 11, 2016 | 06:39 AM
JWA's Avatar
JWA
As already offered you need at bare minimum the factory wiring diagrams or an EVTM as they're otherwise known---typically can be found for cheap on eBay. They would include fuse information too---just as an owners manual will do.
Because we don't know what was done to arrive at your current condition it is difficult to suggest what to do without seeing it all in person.
VanHaulen
Electrical Systems/Wiring
Mar 24, 2013 03:42 PM
VaSheriff
May 10, 2007 08:15 PM
shadowdd
Nov 29, 2004 09:09 PM
rcarnes
1983 - 2012 Ranger & B-Series
Nov 28, 2002 09:21 PM
Becki527
Aerostar
Feb 9, 2002 07:30 PM
