Transmission Fluid Flush On 2000 E150
Old Jan 6, 2016 | 11:16 AM
kincfu's Avatar
kincfu
Hello,
I plan to flush the transmission fluid in the E150. Just want to see if anyone did it before.
Need to know which is the fluid return line into the transmission.
How to indentify the type of transmission I have?
Which type of transmission fluid is best for the E-series van?
Thanks.
Old Jan 6, 2016 | 04:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a tag in the driver's door opening. Find the TR on the tag. Under the TR will be either a U or an E. U means it has a 4R70W, E means it is a 4R100.
Old Jan 7, 2016 | 06:36 AM
JWA's Avatar
JWA
Originally Posted by kincfu
Hello,
Kinda like this: https://www.ford-trucks.com/forums/1...ans-flush.html ??
Old Jan 7, 2016 | 11:55 PM
kincfu's Avatar
kincfu
Thank you Mark and JWA for the reference.
If I let the engine runs about 10 - 30 seconds and so that the transmission fluid drain into a milk jug to about half gallon and then replenish half gallon of new fluid into the transmission, will that work?
I ask because I recently install a transmission cooler on a 2001 Camry for towing and has to flush the transmission fluid through the cooler line (using the above method).
Just not sure if Ford transmission work the way.
Old Jan 8, 2016 | 06:01 AM
JWA's Avatar
JWA
Without offense simply follow the recommendations Mark and I describe---it works well. Doing this 1/2 gallon at a time would take too long---get buckets or containers that allow at least 2-3 gallons at a time between draining and re-filling.
Old Jan 9, 2016 | 01:14 PM
Tom's Avatar
Tom
Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
Old Jan 10, 2016 | 06:44 AM
JWA's Avatar
JWA
Boy, this Mark Kovolsky guy sure does get around here a lot huh?
Old Jan 10, 2016 | 08:47 AM
Mark Kovalsky
I'm EVERYWHERE!
Old Jan 11, 2016 | 06:43 AM
JWA's Avatar
JWA
Originally Posted by Mark Kovalsky
I'm EVERYWHERE!
By Gawd that's the truth----and we here are damned lucky you ARE!
Flea
2009 - 2014 F150
Dec 11, 2013 08:08 AM
tag187
Jul 19, 2008 09:02 PM
TN_VOLS
Mar 13, 2007 10:35 AM
8996EBBroncos
Sep 2, 2002 09:33 PM
