Tuner/chip
Old Jan 9, 2016 | 06:42 PM
Vinford's Avatar
Vinford
Ive always been told the bolts stretch if the engine is heated up? and the reason the engine heats up is because of the EGR.
Well if that's true wouldn't it be safe just to delete the EGR and the engine shouldn't heat up , hence the bolts wont stretch?
Old Jan 9, 2016 | 08:43 PM
Maxium4x4's Avatar
Maxium4x4
Tune a stock truck, you raise the cylinder pressure, that is why most of us use head studs since the raised cylinder pressure is more than the torque to yield head bolt can handle. A stock 6.0L has more HP and better transmission than a chipped 7.3L you are used to.
Yes you can tune a 6.0L but be aware of Pay to Play if you tow with added HP on stock head bolts.
Old Jan 9, 2016 | 11:35 PM
78fordman's Avatar
78fordman
Run the sct tow tune and you will be fine.
Old Jan 12, 2016 | 05:19 PM
megansett's Avatar
megansett
Whats the cheapest way to get back to stock? Have it flashed at a dealership or buy a DP chip with a stock tune available?
Old Jan 12, 2016 | 07:15 PM
Maxium4x4's Avatar
Maxium4x4
6.0l is not chipped, you flash the processor. If you do not have the flash tuner or information you would have to have a Ford Tech flash the truck.
Old Jan 12, 2016 | 08:21 PM
Yahiko's Avatar
Yahiko
Don't forget that FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
can also do the flash.
Sean
6.0L Tech Folder
1L243
30
Nov 2, 2011 10:21 PM
big bucks
Computer Chips & Tuners
Nov 9, 2009 10:19 PM
nedaclu
Jun 21, 2007 06:52 PM
Tater50
Dec 24, 2006 02:11 PM
nantruckit
Jan 29, 2006 11:46 AM
