Hello, all. I've got a '96 F150 302. The heater was never that great and this morning I was blowing icicles.. had the windows down in 8*f weather.. warmer outside! So, while I figure it may just be the foam seal, I've got a suspicion the heater's plugged up. Knowing how she was cared for before she became mine, I would nearly bet on it. I've read some goods and many bads about the new cores. On EBay I see them for cheap, then for around $80-100.00 for said to be OEM Motorcraft.. I've never had trouble with Motorcraft before, but hearing about the newer aluminum cores.. I'm just kind or worried. How do they hold up, or for that matter, what's the one to get these days? I'm fixing to pull mine and get something in it thats supposed to be good, and send mine off to be properly rebuilt at a radiator shop, and if the other holds up well I'll keep it for a spare, or vice versa. As it is the car I learnt to drive on has much better heat.. and it's a good sixty-something years older. ('31 Ford). Any ideas out there? Not much of a job to change I see, but I just want to do it right.
I put in a Spectra Premium heater core a few months ago. It came with the foam weatherstrip already attached. The foam goes all the way around the heater core and keeps it sealed to the heater box.
If you buy the Motorcraft heater core, you have to get your own weatherstrip. It is the bare core only.
FYI the core you remove will have weather strip attached to it. It is old and brittle so you can't really remove it and re-use it.
+1 if its not leaking yet might be worth a try. If not I put a spectre one in my bronco a few months ago as well. A couple of the screws are a PIA to get to behind the dash. It was only like $20-$30 for the part though.
Yes, I've heard of those Spectre ones.. but in my reading they only last a few years for the most part.. heck mine's the original. I find myself wondering if the one I spoke of in the first place is just a rebadge though.. I guess I'll try flushing it, nothing to loose I suppose.
Ill let you know in a few years. Luckily its in my bronco and not the truck. The PO(s) must have taken horrible care of this bronco. When I received it, it had newer freeze plugs and a newer radiator so someone left too much water in it at some point. When I realized the heater core was leaking I was not surprised and replaced immediately.
I am not positive but I feel like that heater core had a lifetime warranty from autozone. So at least I won't be out another $26.
I just pulled the hoses off my '95's heater core and used a garden hose to push some water through briefly. Seemed a little rusty. Swapped to the other outlet and piles of brown crap came out. (Back when it was still warm) Went ahead and backflushed through the radiator too. Watched all manner of gunk come out of the cap opening. Added some chemical flush and drove a week. Did the flushing all over again. Drove around another week with water and flushed everything again. Weather started getting cool so I stopped and got antifreeze back in it. Now that it's really cold the heater kicks. After 20-30 minutes of driving I have to turn it down. Last year it got barely warm and would hardly even melt ice off the windshield.
If and when the heater core starts leaking then and only then will I have any interest in replacing it.
I realize the weather is completely wrong for duplicating exactly what I did but I bet a quick backflush of just the heater core itself would make a major difference.
I had problems with the core on my Dad's 91 F250. After discovering the leak, I replaced it and it broke within a few days. Luckily, the new one was warranted so I replaced it again. It turns out a sticky radiator cap was letting the pressure get too high and the core (being the weak link apparently) was blowing out.
Radiator caps are cheap, so I'd recommend replacing it as well.
one thing the mustang guys do to prevent excess pressure from blowing out a heater core is to make a flow restrictor and put in in the pressure side of the heater hose. they take a copper tube about 3" long, sweat a cap on one end, then drill a 3/8" hole in the cap. that will restrict coolant flow and pressure and prevent a heater core blow out.
I wonder if this foam weatherstrip is what I am missing. Happen to have any pics of what it is supposed to look like?
