heater core retrofit
Old 10-15-2014, 02:41 PM
vanceboroguy
vanceboroguy is offline
vanceboroguy is starting off with a positive reputation.
I have an 1954 F-100 with recirculating heater with defrost tubes. Core is seen inside truck and has grill with ford shield . Most people on here have painted outside edge of grill silver. Anyway, the heater core is shot in mine. I was wondering if anyone have purchased a core from other car or truck that will work in this box? I searched the forum but didn't find the answer. I was hoping a cheaper way to fix my heater instead of re-core of my old core. Thanks
Old 10-15-2014, 04:25 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant futureEffieTrucker has a brilliant future
If you have the heater below, Mid-Fifty (and others) sell the core. (heater radiator)
To my knowledge, there are no modern vehicles that use the same core.
1953-64 Ford F-100 Heater Radiator, Straight/angle - 18476
Old 10-15-2014, 05:48 PM
vanceboroguy
Thanks for the reply. Yes, I have that same heater. I was hoping not to spend $178.00 . I read somewhere that someone had luck with a new one from other truck but for the life of me I can't remember. I think he had to move holes going through firewall a little. Wouldn't matter to me since the cab i'm using came from an f-600 fire truck and it didn't have heater. I have a nice Arvin heater with good heater core in one of my cabs that I could use but it doesn't have holes for defrost. Plus this Ford heater is a good looking unit and tucks well under dash. I might just bite the bullet and go for replacement core. Thanks again!
Old 10-15-2014, 06:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
The one I remember was "fifty-twoF1" who repurposed a modern core, but obviously in an early truck.
Old 10-15-2014, 07:41 PM
carnut122's Avatar
carnut122
carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
If you have the heater(Effie Trucker pictured above), yes, there's a much cheaper alternative. You'll have to drill 2 new holes in the back of the heater box and the tubes aren't as long as the original, but it worked great for me. If somebody doesn't get you a part number by the week-end, PM me and I'll search through my receipts.
Old 10-15-2014, 07:57 PM
3golfjack's Avatar
3golfjack
3golfjack is offline
3golfjack has a good reputation on FTE.3golfjack has a good reputation on FTE.3golfjack has a good reputation on FTE.
The core can be replaced, I found a radiator shop here in the Memphis area ( Moore & Clements ) They took the ends off the old core and attached them to a new core costing 80 dollars.
Old 10-16-2014, 06:46 AM
vanceboroguy
Thanks, I would be interested in part#. I don't have any holes now so wouldn't mind. I would consider re-core of my old core if I could get it done for a reasonable price. Haven't found a radiator place near by to ask yet. My core looks good on ends but has at least 6 or more holes in fins. Thanks again.
Old 10-16-2014, 09:46 AM
midfifty
midfifty is offline
Former Vendor
midfifty is gaining momentum as a positive member of FTE.midfifty is gaining momentum as a positive member of FTE.
Yeah sorry, I wish we could lower the price on our rebuilt cores, but the only radiator place near us charges us a pretty penny to do them, $80 to rebuild it for 3golfjack sounds really good to me!
Old 10-16-2014, 12:13 PM
48ATOY's Avatar
48ATOY
48ATOY is offline
48ATOY is starting off with a positive reputation.
I used a mid 60/70 heater core and added copper plumbing elbows and pipe
was alot cheaper
Joe
Old 10-16-2014, 06:26 PM
3golfjack's Avatar
3golfjack
They used heater core- TSM part#399007 This is used on a 1964 Ford Falcon. core size- 8"x 6" x 2 1/2". They swapped out the end with the inlet and outlet.
Old 10-16-2014, 06:44 PM
vanceboroguy
Thanks so much for the information!
Old 10-16-2014, 11:39 PM
EffieTrucker
It isn't the same type of heater as yours, but I went with a re-core. It was a bit pricey at $180, but I've never seen my core re-popped. Mine is the simple box-type heater.
Old 11-24-2014, 09:09 AM
davidhOK
davidhOK is offline
davidhOK is starting off with a positive reputation.
that ford one looks really similar to chevy trucks without air 67-72. I've replaced it before and they look close in shape
mjsnodgrass
Large Truck
05-27-2016 11:15 AM
nolan94f350
09-24-2015 05:41 PM
4x4 Bart
44
03-07-2014 12:39 PM
abyars111
11-13-2013 08:06 AM
brimis
1997-2006 Expedition & Navigator
09-24-2013 01:09 PM
Quick Reply: heater core retrofit
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
