2003 injector issues
Old Jan 8, 2016 | 07:28 AM
TooManyToys.'s Avatar
TooManyToys.
I thought the '03 T40s were 24lb-ft?
Old Jan 10, 2016 | 06:19 AM
tjustice's Avatar
tjustice
Originally Posted by cheezit
Were they torqued with a torque wrench when they were installed.
Replace the hold down bolt assembly and the injector. Torque it to 26ftlb
Who ever called the fuel pump is the winner, got back together drove it a lil when WOT fue pressure is dropping to 40psi..... So i saying that what is the preferred fuel pump to go back with?????
Old Jan 10, 2016 | 08:50 AM
cheezit's Avatar
cheezit
Truck shoild still run on 40 psi, also fuel pressure wont cause a hydrolock condition.
Old Jan 10, 2016 | 09:53 AM
56fordfella's Avatar
56fordfella
Follow Cheezit's statement 26lb-ft, not one pound less. Learned that the hard way.
Old Jan 10, 2016 | 10:02 AM
tjustice's Avatar
tjustice
Understand on the torque. Its all back together and was running good. Put about 50 miles on it or so... Had to stop at a red light, went to pull out and it was like there was no fuel truck just wouldnt go finally played with pedal and it picked up and took off... Hit entrance ramp and went to accelerate and there was no response... Finally truck picked up and took off, came home put fuel gauge on thats when discovered fuel pressure is not what it should be...
invintive
Dec 26, 2016 06:07 PM
CHayes1104
Apr 6, 2016 10:47 PM
Fordenthusiasts
Apr 28, 2011 01:05 PM
ham-n-swiss
Jun 4, 2010 02:37 PM
tobacco farmer
Apr 21, 2010 04:34 PM
