Injector Replacement
Old Apr 6, 2016 | 07:40 AM
CHayes1104's Avatar
CHayes1104
I may have to replace fuel injector #8 on my 2004 6.0. Aside from doing brakes and rotors, I don't have any experience working on my truck. Was wondering if anyone had any tips or advice for me before starting this, or any videos that could help walk me through. Thanks.
Side note- this is the second injector to go bad in the past few months. Ford also wanted to replace the HFCM, so I'll be doing that as well.
Old Apr 6, 2016 | 07:52 AM
Per4mance's Avatar
Per4mance
Do the blue spring mod first and do a fuel pressure test after that, 60 psi is a favored pressure for these injectors. Run it a little while and see how it does.
Old Apr 6, 2016 | 08:04 AM
CHayes1104's Avatar
CHayes1104
What do I need in order to do a fuel pressure test?
Old Apr 6, 2016 | 08:21 AM
CHayes1104's Avatar
CHayes1104
(Dumb it down for me, I'm very new lol)
Old Apr 6, 2016 | 08:27 AM
mustang_309's Avatar
mustang_309
Look up srmastertech on YouTube he has a bunch of 6.0 videos and are the most detailed out there. As far as tips when installing injectors, make sure you clean the injector cup good, make sure no copper sealing washers are left in the injector cup, make sure you blow out the bolt holes to ensure there is no liquid in the bolt holes as that will prevent proper seat load on the copper sealing washer, make sure every oring gets lubed with fresh oil before they are installed and make sure you use a torque wrench. It is a good idea to blow out every bolt hole before you start reassembly.
Old Apr 6, 2016 | 08:32 AM
CHayes1104's Avatar
CHayes1104
Appreciate it
Old Apr 6, 2016 | 10:07 PM
Sullid01's Avatar
Sullid01
I've watched senior mastertech's video many times. He really goes through all the important steps. It is very important not to drop anything, esp the metal clip on the harness connector (sorry I don't remember to proper name for it). It apparently cannot be retrieved with a magnet. I would watch the videos several times first, then you should be ready.
The fuel pressure test is really just checking a fuel gauge (buy and install ,about $100) which is really important with this engine. The hope is the blue spring (which is cheap) will fix your low pressure situation and avoid replacing the more expensive fuel pump. The low fuel pressure may be killing your injectors one by one.
Old Apr 6, 2016 | 10:47 PM
John Irwin's Avatar
John Irwin
Quick tip... just push in on the little clips and they will release without having to take them out. It changed my life when I discovered this.
Jimmy Cash
Jul 12, 2016 07:42 PM
MarzRickey
Jun 29, 2014 10:48 PM
ham-n-swiss
Jun 4, 2010 02:37 PM
genjock
3.0L V6
Oct 31, 2006 10:26 AM
dm2059
Apr 2, 2006 08:16 AM
