I have looked at a few different posts on transmissions but am unable to verify what trans mine is. Doesn't look like the T9 or 98 as per some of the pictures because most of them look like removable bell housings. The cast numbers on mine are C01T-7006 with a J10 on the other side and then a stamped 8120 on the top at the back where the shift tower bolts to. The shift tower has a cast C41T-7222. It has a partial bell housing cast as part of the trans. It is a 4 speed non syncro behind a 8BA 239 v8 with a 11 inch clutch. The previous drivers didn't have the double clutch experience and rounded most of the gears so that is what i'm trying to locate. I have included some pictures and any help is greatly appreciated. thanks Darrell
thanks most suppliers have no stock and aren't expecting to get any, so i will continue looking now that i'm sure what trans i have. Can u tell my why my questions don't show up on new posts?
Do you value originality? For what it would cost to put that one right, you could likely install any of several more modern trannies with (gasp) synchronizers. Saginaw or B-W 4-speeds are a snap, many other choices, some with overdrive. No love for the crashboxes from my end...
