4x4 switch help
Old Jan 3, 2016 | 04:04 PM
William Mark Brown's Avatar
William Mark Brown
4x4 switch help
Guess I haven't had to many older 4x4 trucks. I'll write what happened then someone clue me in why it didn't work.
I was leaving a parking lot and I saw all the snow at the exit. So I flipped the switch in my late 1999 to 4x4 high. The light came on in the dash so I figured I am in 4x4. I got stuck, the reall wheels turning but not the front. Talk about embarrassing. Here I am in this big 4x4 truck and I got stuck in this puny amount of snow. I was finally able to back out and go a different way. So why did my 4x4 not work?
My truck does seem to have these manual "hubs" on the front. What are they for/do? Is this something I have to turn every time I want 4x4? Can I leave them turned on all winter as I will intermittently need 4x4 in town. I've never had to mess with hubs so have no clue if what I am asking is even correct. I just want my 44 to work when I need it.
Old Jan 3, 2016 | 04:10 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Sounds like you probably have a vacuum leak on the auto hubs. Here is a link about servicing them. First I would suggest turning them in manually and verifying your 4x4 works as expected. Then you can diagnose your vacuum system.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Jan 3, 2016 | 05:09 PM
Walleye Hunter's Avatar
Walleye Hunter
A little more information needs to be had here. I'm going to guess that you are not the first owner of the truck and that is a new to you truck? Regardless of what you have you can manually activate your hubs at the wheels. About a 1/4 turn in the clockwise direction (clockwise to lock, "lock" in common in a good way to remember that) should do the trick. It is possible that they are frozen and won't turn at all. That should get you out of that parking lot with all of those Dodge and Chevy truck owners watching. Then you need to find out if you have manual hubs installed or failing vacuum operated hubs. If they are manual then you have to activate them manually. If they are failed vacuum then you need to chase that problem. And, yes you can leave them locked in for the season, many drivers do that.
Old Jan 3, 2016 | 05:11 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I just replaced the soft vacuum lines to the hubs with 5/32" (4mm) lines. The older/stock ones were hard, brittle and came off the hub quite easily.
Old Jan 3, 2016 | 09:34 PM
Baatzy's Avatar
Baatzy
Looks like they have you covered so far. If you are in doubt as to what hubs you have, post a picture on here and we'll help you out.
Baatzy
Old Jan 4, 2016 | 09:21 PM
crop harvester's Avatar
crop harvester
Turn the dial in the center of Your hubs clockwise,that will engage autolock oem or after market manual locking hubs.
Old Jan 4, 2016 | 09:44 PM
William Mark Brown
Here is a picture of my hubs.
Old Jan 4, 2016 | 09:53 PM
Baatzy's Avatar
Baatzy
From what I can make out, those are the original "auto locking" hubs. The one pictured is in the auto position, if you rotate it about 1/4 turn clockwise (as mentioned above) that will lock this hub in. Same with the other side.
Looks like it is time to put manual hubs in or go through and R&R your autolock system. Some people prefer to go the manual route, as then you know whether they are locked or unlocked. Myself I went with R&R'ing the autolock system, I like the feature and it works good when maintained.
Baatzy
Old Jan 5, 2016 | 07:22 AM
Sous's Avatar
Sous
FTE Emeritus
I remember this way "lock is like a clock". So, turning the dial in the direction of a clock will lock the hub. I took my hubs out to clean and lube them when I first bought the truck. They didn't have a problem before that, but I am sure the service didn't hurt either.
There are quite a few "how to" instructions out there, including one on Guzzles page if I remember correctly.
Old Jan 5, 2016 | 07:50 AM
William Mark Brown
Well I will switch them to lock and hope they work. It's too cold for me to mess with now so it's on my Spring "to do" list now. After work today I'll turn them and test them out.
Old Jan 7, 2016 | 08:24 AM
William Mark Brown
I rotated those hubs clockwise and engaged the 4x4 and it worked correctly. So this means the vacuum line or seal is possibly bad? If so it's something I will attempt to fix in the spring. My spring list is starting to get rather long...
Old Jan 7, 2016 | 08:37 AM
Tugly's Avatar
Tugly
You have another issue. If there is a vacuum leak, you likely don't have floor or vent heat - just defrost. A temporary fix is to go to the auto parts store and pick up some vacuum caps. Separate the vacuum line at the wheel well (upper part of the tube) and cap the plastic tip. I used a machine screw to plug the hose and made sure the tube was zip-tied to prevent hitting/rubbing other moving parts.
When it warms up and you have time, you can use a Mity Vac with a gauge to test each hub - or just replace the hoses as a first step to troubleshoot.
Old Jan 7, 2016 | 09:46 AM
William Mark Brown
I hadn't noticed that since I have only been using defrost in this truck so far. I haven't had to drive the truck far enough or long enough to try a different heat option.
Old Jan 7, 2016 | 12:55 PM
coax9952's Avatar
coax9952
A reminder: Don't drive in 4x4 on dry pavement, things will break.......don't ask.
Old Jan 7, 2016 | 05:58 PM
Walleye Hunter
Your feets will get cold running solely on defrost. The vacuum pump works off of the battery so if you turn your key on, let it sit about 30 seconds for the vacuum pump to work and switch your dash **** from defrost to feet, to dash and back to defrost or feet you should hear the flapper in the heater box working and deflecting the air flow to it's respective outlets. If it stays on defrost your leak is more than your pump can keep up with. My pump is bad, never shuts off but it makes enough vacuum to work the flapper. New pump seems to be about $140 for the OEM.
