Sponsored by: Real Truck
Blower motor
Old Jan 2, 2016 | 11:09 PM
viper1986's Avatar
viper1986
Blower motor
So the Heat and Air work fine on all speeds but when the temp gets really low out side , all the sudden the blower motor will not turn on sucks in the morning waking up frost on window and defrost will not work or blow for that matter anybody have a clue why it works on a normal day but not a really cold day?(f250 5.4 liter yr2000)
Old Jan 2, 2016 | 11:29 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I would pull the blower motor resistor and see what kind of condition it is in. Not sure about the 5.4, but I know on my 2000 7.3 it was a 2 minute job and was in bad need of replacement.
Here is a link to one at Rock Auto.
https://www.rockauto.com/catalog/mor...nid=517&jpid=0
While your there, check the contacts on the plug and see if they are in good shape. Maybe the cold is causing them to have an intermittent connection. That can be replaced if needed too. Someone on the 7.3 forum just did their plug and resistor about a month ago.
Old Jan 3, 2016 | 07:58 AM
projectSHO89's Avatar
projectSHO89
Replace the blower motor itself, not the resistor. If the resistor goes bad, you cannot loose the high speed function.
jstihl
23
Jun 10, 2017 08:18 AM
Tormz
Dec 4, 2013 09:48 PM
meier63
26
Apr 11, 2011 08:17 AM
rywegh
1983 - 2012 Ranger & B-Series
Dec 19, 2007 09:03 AM
chazb86
May 27, 2005 11:59 PM
