Help with the blower motor...
Old Dec 3, 2013 | 07:55 PM
Tormz's Avatar
Tormz
Blower motor turns on and off randomly even when not moving. When it dose function it workes fine on all speeds. The relay was switched out but issue still occurs. Is there any other thing it could be or is it it to start looking for a short.
Help needed.
Old Dec 3, 2013 | 09:24 PM
carltonwebb's Avatar
carltonwebb
I DO not think u are saying the motor comes on with the key off...if that is the case ignore the rest of this.
Check the connections at the blower motor under the hood. Check the connector at the resistor as well next to the blower motor. If it has gotten hot and melted it, that could be the problem. If you do not see anything else, then it could be the brushes in the motor are worn out and they only make contact when jostled.
Old Dec 3, 2013 | 09:44 PM
white Buffalo's Avatar
white Buffalo
if you are talking about the blower motor on the passenger side near the fire wall, the one that blowes the heat & A/C to the cab:
When it goes out again, tap the blower with a hammer, if it comes back on you will most likely need to replace the blower. The hammer trick worked for me for about a month or so but the blower quite entirely after that. I can't recall how much it was to replace it, but it wasn't expensive.
Old Dec 3, 2013 | 10:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I did a full write up on the blower motor and resistor with pics in the excursion forum recently. I'll try to find it, but you can go there and search for it as well. Easy job.
Old Dec 3, 2013 | 10:10 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Here it is: https://www.ford-trucks.com/forums/1...with-pics.html
Old Dec 3, 2013 | 10:29 PM
white Buffalo
Excellent write up Mike......
Originally Posted by Nicmike
Old Dec 4, 2013 | 07:47 AM
Tugly's Avatar
Tugly
My blower motor started acting up this year and I just replaced it. No problems since replacement.
Old Dec 4, 2013 | 06:14 PM
trk98's Avatar
trk98
If you happen to have an excursion with EATC (climate control) the blowers have a speed control module in place if a resistor. They have been a problem area on other vehicles equipped with EATC. Not sure if the superdutys were ever equipped. If you have regular manual controls I may still suspect the resistor or pigtail may be melted.
Old Dec 4, 2013 | 08:11 PM
Tailgate77478's Avatar
Tailgate77478
TORMZ:
Pretty important that you fill out your "Signature" in your profile, so that everyone knows the specifics about your vehicle. Such as F250/E350/Excursion, 2wd/4wd or dually, any mods, etc. It's not so much a "brag sheet" as it is to help everyone figure out the most relevant help for your configuration. Hence trk98's post of "if you have this" vs. "that"...etc. We are all here to help...
Old Dec 4, 2013 | 09:48 PM
Tormz's Avatar
Tormz
Excellent write up.. Thanks it was very useful. Works better than ever before appreciate all the help.
jstihl
23
Jun 10, 2017 08:18 AM
brandonellisce
2009 - 2014 F150
Jun 20, 2015 11:46 PM
brandonellisce
2009 - 2014 F150
Jun 19, 2015 05:58 PM
chazb86
May 27, 2005 11:59 PM
