Help Blower Motor on high only!
Old May 27, 2005 | 12:19 PM
chazb86's Avatar
chazb86
Question Help Blower Motor on high only!
86 F150 302 My blower motor works on one speed "high". I changed the switch out still the same, do this model truck have a blower motor relay? If so where would it be located? I tried 4 motors 2 did not fit, one was from a salvage yard (work on high only) and the other just did not work. So I'm back to the original motor.
Old May 27, 2005 | 01:55 PM
jtmerritt's Avatar
jtmerritt
Could be the blower motor resistor pack is bad. Usually it is mounted to the blower case so the resitors sit in the airstream for cooling. Follow the wiring from the blower motor and it should lead you to the resistors.
john
Old May 27, 2005 | 11:59 PM
Holmesuser01's Avatar
Holmesuser01
You will find the resistor pack to the right and slightly below the blower motor. It is probably orange in color and has 2 sets of wires attached. Check to be sure that the connectors are clean.
My resistor pack died due to a build-up of leaves and crud. I cleaned out all the crud and replace the resistors. No problem since.
dssocialwrk
Nov 30, 2018 04:55 AM
jdb1967
Jan 17, 2014 12:39 PM
2002sport
Escape & Escape Hybrid
Oct 23, 2010 11:01 AM
Lura
Sep 16, 2010 09:16 PM
KRAZY KRAMER
Feb 20, 2007 06:52 AM
