Dashboss users
Old Jan 2, 2016 | 04:49 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Dashboss users
For those using the fuel pressure transducer, where did you tap into get your 5v in?
I am leaning towards the MAF sensor wire unless there is something easier??
Old Jan 2, 2016 | 05:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I got mine from the cab... PTOVREF Orange/Red wire in the bundle.
Josh
Old Jan 2, 2016 | 07:28 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Josh
Thanks Josh. I was able to locate the wire. So each one of the wires in that bundle have heat shrink at the end. Is there a resistor in the heat shrink?
Old Jan 2, 2016 | 08:11 PM
Bullitt390's Avatar
Bullitt390
I think the heat shrink is keep the bundle from shorting out.
Josh
Old Jan 3, 2016 | 02:11 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Low fuel pressure
Just finished up the DB fuel pressure gauge install. I am setting at 52-55 at idle and drops to 42 under moderate acceleration. Cruising speed its around 50-52.
I have the blue spring and new motorcraft filters. I guess the pump is weak?
Old Jan 3, 2016 | 02:40 PM
Bullitt390's Avatar
Bullitt390
You put everything back as it was?
Tough to say if the FP is weak or the Blue Spring didn't raise it enough. I'm sitting at 70+ psi at most times
Josh
Old Jan 3, 2016 | 03:00 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Josh
Not sure what you mean? I didn't uninstall it if that is what you are asking. I installed the blue spring right after I bought the truck 2ish years ago.
Here is a few pics of the install and I used the PTOVREF wire you suggested. I also confirmed that I have 5v.
Old Jan 3, 2016 | 03:22 PM
Bullitt390's Avatar
Bullitt390
Certainly is possible the BP is getting weak. Could try stretching it a smidge or just buying a new blue spring by itself on eBay.
Don't forget to adjust the high and low of the sensor bias. Mine is 4.5v 100 psi max.
Old Jan 3, 2016 | 06:07 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Your the man Josh. After setting up the perimeters per the tutorial the fuel pressure at idle is now 70-71 psi!! I feel good about that!
SixGunCaliforniaKid
18
Jul 21, 2015 11:26 PM
bruno2
22
Mar 17, 2014 11:38 PM
housedad
Electrical Systems/Wiring
Sep 24, 2012 08:36 AM
opus
34
Jun 1, 2006 09:16 PM
TryMe
Jan 14, 2003 08:47 PM
