F350 Gift
Old Jan 2, 2016 | 02:45 PM
dybeepvw's Avatar
dybeepvw
F350 Gift
Just inherited an 1990 F350 4x4 automatic lwb regular cab with 460 engine. It is quite a climbing and torque beast. Has 173,000 mostly hwy miles and still is very strong. Gas mileage is 7.5 - 9.5. Is this about all it will get? It is mostly in town in a rural AZ area. It also has 4.10L gears. Thanks for any response.
Old Jan 2, 2016 | 03:13 PM
Nothing Special's Avatar
Nothing Special
That seems a little low. But if it's mostly town driving it's probably about right. I get 9-10 with my F-250 CCSB 4WD 460, E4OD, 4.10 gears. That's "suburban commuting". A lot of short freeway drives with the rest around town. It goes up to a solid 10 on the freeway
Old Jan 2, 2016 | 03:17 PM
bashby's Avatar
bashby
Youve got a c6 I believe. No od button, right. You'll lose a couple mpg without the lockup converter and overdrive the e4od offers. The c6 is less prone to problems and way cheaper to rebuild though.
Old Jan 2, 2016 | 03:18 PM
toby tough's Avatar
toby tough
That's about as good as it gets for the most part. Might try a good tune up and push the timing ahead a degree or two. Not sure advancing the timing will help but you can always set it back. I had a 75 3/4 ton and got 10 pretty consistently. It had a 3.73 rear.
Old Jan 2, 2016 | 03:45 PM
DeereFord300's Avatar
DeereFord300
I believe by 1990 all of the heavy duty trucks had the E4OD as the stock auto trans, but unless it's a bare bones model I doubt it has the C6. The E4OD with 4.10s are a real good torque/mileage balance
Old Jan 2, 2016 | 03:51 PM
bashby's Avatar
bashby
I think you are right for the most part. I was thinking the e4od was introduced later. The c6 was available until 94 I believe.
Old Jan 2, 2016 | 04:16 PM
dybeepvw's Avatar
dybeepvw
It does have the E4OD. I have changed the cap and rotor, planning to do the plugs, air filter, fuel filter next, plug wires still look new.
Old Jan 2, 2016 | 05:15 PM
Duwop's Avatar
Duwop
Post a pic of the truck when you get a chance, we love pics
ja2488
39
Jan 5, 2011 12:13 PM
mikey89014
63
Dec 11, 2010 03:20 AM
buffalobob
21
Mar 16, 2007 02:17 AM
Gold Dog
Jun 30, 2006 04:55 PM
User 71024
17
Sep 28, 2005 06:14 PM
