I did it freehand on the truck. It is in line with the zerk when the truck is unloaded.
Some of the old Fords did have a zerk there. Ours are new and improved.
gotta love new and improved.. So i had a thought.. when you drop the drive line take a hand grinder and get real steady, have someone start the engine and I bet the shaft will spin so you just keep the grinder steady and the shaft rotates while you are pressing grinder to splines..
does that sound like a plan??
not to be a jerk.... but PLEASE FILM THAT!!! that section of drive shaft will flail around sooooo bad! with no control other than killing the engine or putting the trans in neutral or park which it will grind into park.
so with the yoke shaft with the center bearing still attached to body and the front shaft still attached to trans will have that much play.. while i have not seen that It seems the yoke shaft should be quite stable.
just asking the question.
i personally do not think it will be stable enough with a high speed tool in hand and a running & moving drive train... turning the shaft by hand with engine off would be better....and even better might be having the part on the work bench.
what you had described earlier is just plain sketchy. there is no braking function period on the driveshaft, and when it is disconnected from the rear axle it can spin quite quickly in 1st gear at idle. youtube search broken driveshafts, i would bet you can find some videos...
That Ford grease is a fix that is a problem on most their pick-ups from what I understand late 80's to mid 2000's. I have a friend who specializes in drivelines and works on Ford's quite a bit. He told me that grease has a medium or filler (fiberglass, ground fiberglass or something like that, can't remember) that essentially closes the tolerances in the slip yoke. He gave me some for when I do mine this spring. He says once their done properly, he's only every had to rework one and it was on a lifted 350 who liked mud.
He did tell me that those who don't use it have to regularly service it again.
Disclaimer - It's all second-hand knowledge, but I trust this guy. He has good taste in beer and friends....
is that the TSB "ford" grease that has been mentioned or something else .
Just thought I would bring this back up to report that I am confident that the "CRC synthetic brake grease with PTFE" should be an excellent substitute for a spline grease. I am on at minimum 3 years (probably more like 5) without the clunk returning. It was easy to find (advanced) and a fraction of the price of the Ford Blue. I think the key thing here may be the PTFE. Anyway, I think this product will work excellent in a pinch and may be as good as anything.
