Injectors
Old Dec 28, 2015 | 08:19 PM
Cmbrown's Avatar
Cmbrown
Injectors
How much damage would it cause if I forgot to remove the plastic tip before I installed a new injector?
Old Dec 28, 2015 | 08:25 PM
navistarnut's Avatar
navistarnut
Are you asking after you started it already?
Old Dec 28, 2015 | 08:39 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Old Dec 28, 2015 | 09:00 PM
KDAVID1's Avatar
KDAVID1
Interesting.........
Old Dec 28, 2015 | 09:20 PM
Cmbrown's Avatar
Cmbrown
Yes I have started it
Old Dec 28, 2015 | 09:23 PM
Cmbrown's Avatar
Cmbrown
It actually ran really well for about an hour and then it went to hell
Old Dec 28, 2015 | 10:59 PM
FL SuperDuty's Avatar
FL SuperDuty
if it's running like hell i'd say alot
Old Dec 28, 2015 | 11:02 PM
FL SuperDuty
pull the injectors out and let us know what you find. id imagine the amount of fuel pressure that these things have would shoot the plastic straight into the combustion chamber
Old Dec 29, 2015 | 02:43 AM
Yahiko's Avatar
Yahiko
The tip of the injector almost reaches into the chamber. Most likely they blew off
and may be in the exhaust (turbine) side of the turbo. They are a soft plastic.
As already said I would pull them back out. The reason I I am willing to bet that
not all of the plastic went into the chamber and some may of help the injector up
just a bit and now that they have heated the torque that was there has crushed that
soft plastic and not you have gassed blowing past the copper washer. You will need
one O-ring kit for each injector. Brush out each injector bore. Place new O-rings and
washer on the injector and apply fresh engine oil to the O-rings and reinstall.
Also I would clean the turbo to make sure that there is not any plastic gumming up
things in there.
Happy New Year 2016 is almost here
Sean
6.0L Tech Folder
mudfuel06
Modular V10 (6.8l)
Jul 22, 2013 07:02 AM
dwdranch
May 15, 2013 07:24 AM
Roasted7
Sep 27, 2012 11:18 AM
RP27G8G
Jul 7, 2009 11:56 PM
Jerrod
Feb 20, 2006 07:33 AM
